Help Center/
      API Gateway/
        User Guide (ME-Abu Dhabi Region)/
        API Management/
        Importing and Exorting APIs/
        Extended Definition/
      x-apigateway-backend.mockEndpoints
Meaning: Mock backend service definition.
Scope of effect: x-apigateway-backend
Example:
paths:
  '/users/{userId}':
    get:
      produces:
        - "application/json"
      parameters:
        - name: "X-Auth-Token"
          description: "Authentication token"
          type: "string"
          in: "header"
          required: true
      responses:
        default:
          description: "default response"
      x-apigateway-request-type: "public"
      x-apigateway-backend:
        type: "MOCK"
        mockEndpoints:
          result-content: "mocked"
       Parameter  |
       Mandatory  |
       Type  |
       Description  |
       result-content  |
       Yes  |
       String  |
       Mock response.  |
   Parent topic: Extended Definition
