Response Headers
The following table describes the response headers that APIG adds to the response returned when an API is called.
X-Apig-Mode: debug indicates API debugging information.
       Response Header  |
       Description  |
       Remarks  |
       X-Request-Id  |
       Request ID.  |
       Returned for all valid requests.  |
       X-Apig-Latency  |
       Duration from the time when APIG receives a request to the time when the backend returns a message header.  |
       Returned only when the request header contains X-Apig-Mode: debug.  |
       X-Apig-Upstream-Latency  |
       Duration from the time when APIG sends a request to the backend to the time when the backend returns a message header.  |
       Returned only when the request header contains X-Apig-Mode: debug and the backend type is not Mock.  |
       X-Apig-RateLimit-api  |
       API request limit information. Example: remain:9,limit:10,time:10 second.  |
       Returned only when the request header contains X-Apig-Mode: debug and a limit has been configured for the number of times the API can be called.  |
       X-Apig-RateLimit-user  |
       User request limit information. Example: remain:9,limit:10,time:10 second.  |
       Returned only when the request header contains X-Apig-Mode: debug and a limit has been configured for the number of times the API can be called by a user.  |
       X-Apig-RateLimit-app  |
       Credential request limit information. Example: remain:9,limit:10,time:10 second.  |
       Returned only when the request header contains X-Apig-Mode: debug and a limit has been configured for the number of times the API can be called by a credential.  |
       X-Apig-RateLimit-ip  |
       IP address request limit information. Example: remain:9,limit:10,time:10 second.  |
       Returned only when the request header contains X-Apig-Mode: debug and a limit has been configured for the number of times the API can be called by an IP address.  |
       X-Apig-RateLimit-api-allenv  |
       Default API request limit information. Example: remain:199,limit:200,time:1 second.  |
