Monitoring Metrics
Introduction
This section describes the metrics that APIG reports to the Cloud Eye service. You can view metrics and alarms by using the Cloud Eye console.
Namespace
SYS.APIC
Metrics
Table 1 Metric description
Metric ID
Metric Name
Value Range
Monitored Object and Dimension
Monitoring Period (Minute)
requests
Requests
Number of times that all APIs in a dedicated gateway have been called.
≥ 0
Monitored object: dedicated API gateway
Dimension: instance_id
error_4xx
4xx Errors
Number of times that all APIs in the dedicated gateway return a 4xx error.
≥ 0
error_5xx
5xx Errors
Number of times that all APIs in the dedicated gateway return a 5xx error.
≥ 0
throttled_calls
Throttled API Calls
Number of times that all APIs in the dedicated gateway have been throttled.
≥ 0
avg_latency
Average Latency
Average latency of all APIs in the gateway.
≥ 0
Unit: ms
max_latency
Maximum Latency
Maximum latency of all APIs in the gateway.
≥ 0
Unit: ms
req_count
Requests
Number of times that an API has been called.
≥ 0
Monitored object: API
Dimension: api_id
req_count_2xx
2xx Responses
Number of times that the API returns a 2xx response.
≥ 0
Dimension: api_id
req_count_4xx
4xx Errors
Number of times that the API returns a 4xx error.
≥ 0
Dimension: api_id
req_count_5xx
5xx Errors
Number of times that the API returns a 5xx error.
≥ 0
Dimension: api_id
req_count_error
Total Errors
Total number of errors returned by the API.
≥ 0
Dimension: api_id
avg_latency
Average Latency
Average latency of the API.
≥ 0
Unit: ms
Dimension: api_id
max_latency
Maximum Latency
Maximum latency of the API.
≥ 0
Unit: ms
Dimension: api_id
input_throughput
Incoming Traffic
Incoming traffic of the API.
≥ 0
Unit: Byte, KB, MB, or GB
Dimension: api_id
output_throughput
Outgoing Traffic
Outgoing traffic of the API.
≥ 0
Dimension: api_id
node_system_load
Node System Load
Load details of a gateway node on the data plane. 1 means low water level, 2 means medium water level, and 3 means high water level.
1, 2, 3
Unit: count
Monitored object: gateway node
Dimension: node_ip
node_cpu_usage
Node CPU Usage
CPU usage details of a gateway node on the data plane.
≥ 0
Unit: %
Dimension: node_ip
node_memory_usage
Node Memory Usage
Memory usage details of a gateway node on the data plane.
≥ 0
Unit: %
Dimension: node_ip
Dimension
Table 2 Monitoring dimensions
Key
Value
instance_id
Dedicated gateway
instance_id,node_ip
Dedicated gateway node
instance_id,api_id
API
