- What's New
- Function Overview
- Service Overview (2.0)
- Billing (2.0)
- Getting Started (2.0)
User Guide (2.0)
- Using IAM to Grant Access to AOM
Connecting to AOM
- Connecting to AOM
- Managing Collector Base UniAgent
- Connecting Businesses to AOM
- Connecting Applications to AOM
Connecting Middleware and Custom Plug-ins to AOM
- Overview About Middleware and Custom Plug-in Connection to AOM
Connecting Middleware to AOM
- Ingesting MySQL Metrics to AOM
- Ingesting Redis Metrics to AOM
- Ingesting Kafka Metrics to AOM
- Ingesting Nginx Metrics to AOM
- Ingesting MongoDB Metrics to AOM
- Ingesting Consul Metrics to AOM
- Ingesting HAProxy Metrics to AOM
- Ingesting PostgreSQL Metrics to AOM
- Ingesting Elasticsearch Metrics to AOM
- Ingesting RabbitMQ Metrics to AOM
- Ingesting Other Middleware Metrics to AOM
- Connecting Custom Plug-ins to AOM
- Managing Middleware and Custom Plug-in Collection Tasks
- Connecting Running Environments to AOM
- Connecting Cloud Services to AOM
- Connecting Open-Source System to AOM
- Managing Log Ingestion
(New) Connecting to AOM
- AOM Access Overview
- Connecting Components to AOM
- Overview About Middleware Connection to AOM
- Managing Middleware Collection Tasks
- Ingesting Data to AOM Using Open-Source APIs and Protocols
- Managing Metric and Log Ingestion
- Observability Metric Browsing
- Dashboard Monitoring
- Alarm Monitoring
- (New) Log Management
- Log Management (Old)
Prometheus Monitoring
- Prometheus Monitoring Overview
- Managing Prometheus Instances
- Managing Prometheus Instance Metrics
- Using Prometheus Monitoring to Monitor CCE Cluster Metrics
- Configuring Multi-Account Aggregation for Unified Monitoring
- Configuring Metric Collection Rules for CCE Clusters
- Configuring Recording Rules to Improve Metric Query Efficiency
- Configuring Data Multi-Write to Dump Metrics to Self-Built Prometheus Instances
- Setting Metric Storage Duration
- Monitoring Prometheus Instance Metrics Through Dashboards
- Configuring the Remote Read Address to Enable Self-built Prometheus to Read Data from AOM
- Configuring the Remote Write Address to Report Self-Built Prometheus Data to AOM
- Checking Prometheus Instance Data Through Grafana
- Checking the Number of Metric Samples Reported by Prometheus Instances
- Infrastructure Monitoring
- Application Insights
- O&M Management
- Global Settings
- Querying AOM Traces
- Migrating Data from AOM 1.0 to AOM 2.0
Best Practices (2.0)
- AOM Best Practices
- Building a Comprehensive Metric System
- Alarm Noise Reduction
- Unified Metric Monitoring
- Customizing OS Images to Automatically Connect UniAgent
- Connecting Self-Built Middleware in the CCE Container Scenario
- Interconnecting Third-Party/IDC/Huawei Cloud Cross-Region Self-Built Prometheus with AOM Prometheus Instances
FAQs (2.0)
- Dashboard
- Alarm Management
- Log Analysis
- Application Monitoring
Collection Management
- Are ICAgent and UniAgent the Same?
- What Can I Do If an ICAgent Is Offline?
- Why Is an Installed ICAgent Displayed as "Abnormal" on the UniAgent Installation and Configuration Page?
- Why Can't I View the ICAgent Status After It Is Installed?
- Why Can't AOM Monitor CPU and Memory Usage After ICAgent Is Installed?
- How Do I Obtain an AK/SK?
- FAQs About UniAgent and ICAgent Installation
- How Do I Enable the Nginx stub_status Module?
- Why Does APM Metric Collection Fail?
- Why Cannot the Installation Script Be Downloaded When I Try to Install UniAgent on an ECS?
- CMDB (Unavailable Soon)
O&M Management (Unavailable Soon)
- How Can I Obtain the OBS Permission for Installing Packages?
- Why Can't Scheduled Tasks Be Triggered?
- Can I Specify Script Parameters and Hosts During Job Execution?
- Why Is a Parameter Error Displayed When I Create a Scheduled Task Using a Cron Expression?
- How Can I Set a Review for an Execution Plan?
- Why Is "delete success:{}" Displayed (Files Cannot Be Deleted) During Disk Clearance?
- What Can I Do If the Execution Plan Is Not Updated After I Modify the Job?
- What Can I Do If "agent not found" Is Displayed?
- Why Are the Hosts Listed in Execution Logs Inconsistent with Those I Configured for a Task?
- Why Did a Task Fail to Execute?
- Other FAQs
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
Alarm
- Querying the Event Alarm Rule List
- Adding an Event Alarm Rule
- Modifying an Event Alarm Rule
- Deleting an Event Alarm Rule
- Querying Events and Alarms
- Counting Events and Alarms
- Reporting Events and Alarms
- Obtaining the Alarm Sending Result
- Deleting a Silence Rule
- Adding a Silence Rule
- Modifying a Silence Rule
- Obtaining the Silence Rule List
- Querying an Alarm Action Rule Based on Rule Name
- Adding an Alarm Action Rule
- Deleting an Alarm Action Rule
- Modifying an Alarm Action Rule
- Querying the Alarm Action Rule List
- Querying Metric or Event Alarm Rules
- Adding or Modifying Metric or Event Alarm Rules
- Deleting Metric or Event Alarm Rules
Monitoring
- Querying Time Series Objects
- Querying Time Series Data
- Querying Metrics
- Querying Monitoring Data
- Adding Monitoring Data
- Adding or Modifying One or More Service Discovery Rules
- Deleting a Service Discovery Rule
- Querying Existing Service Discovery Rules
- Adding a Threshold Rule
- Querying the Threshold Rule List
- Modifying a Threshold Rule
- Deleting a Threshold Rule
- Querying a Threshold Rule
- Deleting Threshold Rules in Batches
- Querying Expression Calculation Results in a Specified Period Using the GET Method
- (Recommended) Querying Expression Calculation Results in a Specified Period Using the POST Method
- Querying the Expression Calculation Result at a Specified Time Point Using the GET Method
- (Recommended) Querying Expression Calculation Results at a Specified Time Point Using the POST Method
- Querying Tag Values
- Obtaining the Tag Name List Using the GET Method
- (Recommended) Obtaining the Tag Name List Using the POST Method
- Querying Metadata
- Log
- Prometheus Instance
- Configuration Management
CMDB (AOM 2.0)
- Creating an Application
- Deleting an Application
- Querying the Details of an Application
- Modifying an Application
- Adding a Component
- Deleting a Component
- Querying the Details of a Component
- Modifying a Component
- Creating an Environment
- Deleting an Environment
- Querying the Details of an Environment
- Modifying an Environment
- Querying the Resource List of a Node
- Querying the Details of an Application Based on the Application Name
- Querying the Details of an Environment Based on the Environment Name
- Querying the Details of a Component Based on the Component Name
- Adding a Sub-application
- Deleting a Sub-application
- Modifying a Sub-application
Automation (AOM 2.0)
- Creating a Task
- Updating a Task
- Operating a Paused Task
- Obtaining the Execution Details of a Workflow
- Terminating a Task
- Querying a Script
- Querying the Script Version
- Performing Fuzzy Search on the Job Management Page
- Querying Execution Plans (Custom Templates) Based on Job ID
- Querying the Details of an Execution Plan
- Querying Tasks
- Querying the Execution History of a Task
- Executing a Workflow
Alarm
- Historical APIs
- Examples
- Appendix
- SDK Reference
Service Overview (1.0)
- What Is AOM?
- Product Architecture
- Functions
- Application Scenarios
- Edition Differences
Metric Overview
- Introduction
- Network Metrics and Dimensions
- Disk Metrics and Dimensions
- Disk Partition Metrics
- File System Metrics and Dimensions
- Host Metrics and Dimensions
- Cluster Metrics and Dimensions
- Container Metrics and Dimensions
- VM Metrics and Dimensions
- Instance Metrics and Dimensions
- Service Metrics and Dimensions
- Security
- Restrictions
- Privacy and Sensitive Information Protection Statement
- Relationships Between AOM and Other Services
- Basic Concepts
- Permissions
- Billing
- Change History
- Getting Started (1.0)
User Guide (1.0)
- Overview
- Subscribing to AOM
- Permissions Management
- Connecting Resources to AOM
- Monitoring Overview
- Alarm Management
- Resource Monitoring
- Log Management
- Resource Groups
- Auditing
- Upgrading to AOM 2.0
- Best Practices (1.0)
FAQs (1.0)
- User FAQs
Consultation FAQs
- What Is the Billing Policy of AOM?
- What Are the Usage Restrictions of AOM?
- What Are the Differences Between AOM and APM?
- How Do I Distinguish Alarms from Events?
- What Is the Relationship Between the Time Range and Statistical Cycle?
- Does AOM Display Logs in Real Time?
- Will Container Logs Be Deleted After They Are Dumped?
- How Can I Do If I Cannot Receive Any Email Notification After Configuring a Threshold Rule?
- Why Are Connection Channels Required?
Usage FAQs
- What Can I Do If I Do Not Have the Permission to Access SMN?
- What Can I Do If Resources Are Not Running Properly?
- How Do I Set the Full-Screen Online Duration?
- What Can I Do If the Log Usage Reaches 90% or Is Full?
- How Can I Check Whether a Service Is Available?
- Why Is the Status of an Alarm Rule Displayed as "Insufficient"?
- Why the Status of a Workload that Runs Normally Is Displayed as "Abnormal" on the AOM Page?
- How Do I Create the apm_admin_trust Agency?
- How Do I Obtain the AK/SK by Creating an Agency?
- What Is the Billing Policy of Logs?
- Why Can't I See Any Logs on the Console?
- Why Can't the Host Be Monitored After ICAgent Is Installed?
- Why Is "no crontab for root" Displayed During ICAgent Installation?
- Why Can't I Select an OBS Bucket When Configuring Log Dumping on AOM?
- Why Can't Grafana Display Content?
- Videos
More Documents
User Guide (1.0) (Kuala Lumpur Region)
Service Overview
- What Is AOM?
- Functions
Metric Overview
- Introduction
- Restrictions
- Basic Concepts
- Permissions
- Getting Started
- Alarm Management
- Log Management
- Auditing
- User FAQs
Consultation FAQs
Usage FAQs
- Change History
Service Overview
User Guide (2.0) (Kuala Lumpur Region)
- Getting Started
- Introduction
- Access Center
- Dashboard
- Alarm Management
Metric Analysis
- Metric Browsing
- Resource Usage Statistics
- Log Analysis (Beta)
- Container Insights
- Process Monitoring
- Collection Management
- Remarks
- Auditing
- Overview
- Dashboard
- Alarm Management
- Log Analysis
- Why Is an Installed ICAgent Displayed as "Abnormal" on the Agent Management Page?
- FAQs About ICAgent Installation
- Other FAQs
- Change History
- Before You Start
- API Overview
- Calling APIs
APIs
Alarm
Monitoring
- Querying Metrics
- Log
Alarm
- Examples
- Appendix
- Change History
- Getting Started
- User Guide
- Obtaining an AK/SK
- How Can I Do If I Do Not Have the Permission to Access SMN?
- How Do I Distinguish Alarms and Events?
- Why the Status of a Workload that Runs Normally Is Abnormal on the AOM Page?
API Reference(ME-Abu Dhabi Region)
- Before You Start
- API Overview
- Calling APIs
APIs
Monitoring (v1)
- Querying Metrics
- Adding or Modifying One or More Application Discovery Rules
- Deleting an Application Discovery Rule
- Querying Application Discovery Rules
- Auto Scaling
- Log
Monitoring (v1)
- Appendix
User Guide (Ankara Region)
- Getting Started
- User Guide
- Why Is the Application Status Normal but the Component Status Abnormal?
- Best Practices
- Change History
API Reference (Ankara Region)
- Before You Start
- API Overview
- Calling APIs
APIs
Monitoring (v1)
- Querying Metrics
- Monitoring (v2)
- Auto Scaling
- Log
- Events/Alarms
- Agent
- Application Discovery Rules
- Querying Metadata
- Querying the Calculation Results of a PromQL Expression in a Specified Period Based on Prometheus Instance
- Querying the Calculation Result of a PromQL Expression at a Specified Time Point Based on Prometheus Instance
- Querying the Values of a Tag Based on Prometheus Instance
- Obtaining the Tag Name List Based on Prometheus Instance
- Querying Metadata Based on Prometheus Instance
Monitoring (v1)
- Appendix
- Change History
Configuring Application Discovery
AOM can discover applications and collect their metrics based on configured rules. Application discovery supports both automatic and manual configuration. This section focuses on manual configuration.
- Automatic configuration
After you install the ICAgent on a host according to Installing the ICAgent, the ICAgent automatically discovers applications on the host based on Built-in Service Discovery Rules and displays them on the Application Monitoring page.
- Manual configuration
After you add a custom application discovery rule on the application discovery page and apply it to the host where the ICAgent is installed (for details, see Installing the ICAgent), the ICAgent discovers applications on the host based on the configured service discovery rule and displays them on the Application Monitoring page.
Filtering Rules
The ICAgent will periodically detect processes on the target host. The effect is similar to that of running the ps -e -o pid,comm,lstart,cmd | grep -v defunct command. Then, the ICAgent checks whether processes match the filtering rules in Table 1. If a process meets a filtering rule, the process is filtered out and is not discovered by AOM. If a process does not meet any filtering rules, the process is not filtered and is discovered by AOM.
ICAgent detection results may as follows:
PID COMMAND STARTED CMD 1 systemd Tue Oct 2 21:12:06 2018 /usr/lib/systemd/systemd --switched-root --system --deserialize 20 2 kthreadd Tue Oct 2 21:12:06 2018 [kthreadd] 3 ksoftirqd/0 Tue Oct 2 21:12:06 2018 (ksoftirqd/0) 1140 tuned Tue Oct 2 21:12:27 2018 /usr/bin/python -Es /usr/sbin/tuned -l -P 1144 sshd Tue Oct 2 21:12:27 2018 /usr/sbin/sshd -D 1148 agetty Tue Oct 2 21:12:27 2018 /sbin/agetty --keep-baud 115200 38400 9600 hvc0 vt220 1154 docker-containe Tue Oct 2 21:12:29 2018 docker-containerd -l unix:///var/run/docker/libcontainerd/docker-containerd.sock --shim docker-containerd-shim --start-timeout 2m --state-dir /var/run/docker/libcontainerd/containerd --runtime docker-runc --metrics-interval=0
Filtering Rule |
Example |
If the COMMAND value of a process is docker-containe, vi, vim, pause, sshd, ps, sleep, grep, tailf, tail, or systemd-udevd, and the process is not running in the container, the process is filtered out and is not discovered by AOM. |
In the preceding information, the process whose PID is 1154 is not discovered by AOM because its COMMAND value is docker-containe. |
If the CMD value of a process starts with [ and ends with ], the process is filtered out and is not discovered by AOM. |
In the preceding information, the process whose PID is 2 is not discovered by AOM because its CMD value is [kthreadd]. |
If the CMD value of a process starts with ( and ends with ), the process is filtered out and is not discovered by AOM. |
In the preceding information, the process whose PID is 3 is not discovered by AOM because its CMD value is (ksoftirqd/0). |
If the CMD value of a process starts with /sbin/, the process is filtered out and is not discovered by AOM. |
In the preceding information, the process whose PID is 1148 is not discovered by AOM because its CMD value starts with /sbin/. |
AOM provides Default_Rule, ServiceStage provides servicestage-default-rule, and ICAgent has the built-in Sys_Rule. These rules are executed on all hosts, including those added later. The priorities of the three built-in discovery rules are as follows: Sys_Rule > servicestage-default-rule > Default_Rule. Rule details are as follows:
- For the component name, obtain the value of -Dapm_tier in the command, the value of the environment variable PAAS_APP_NAME, and the value of -Dapm_tier of the environment variable JAVA_TOOL_OPTIONS based on the priorities in descending order.
- For the application name, obtain the value of -Dapm_application in the command, the value of environment variable PAAS_MONITORING_GROUP, and the value of -Dapm_application in the environment variable JAVA_TOOL_OPTIONS based on the priorities in descending order.
PAAS_MONITORING_GROUP=atpd-test PAAS_APP_NAME=atps-demo JAVA_TOOL_OPTIONS=-javaagent:/opt/oss/servicemgr/ICAgent/pinpoint/pinpoint-bootstrap.jar -Dapm_application=atpd-test -Dapm_tier=atps-demo
sys_rule (built-in application discovery rule) is used to discover CCE workloads in the CCE scenario (except the APM scenario).
servicestage-default-rule (can be disabled)
Detect the processes whose environment variables contain CAS_APPLICATION_NAME, CAS_COMPONENT_NAME, and CAS_ENVIRONMENT_NAME.
Obtain the value of the environment variable CAS_COMPONENT_NAME and combine it as the component name.
Obtain the value of the environment variable CAS_APPLICATION_NAME and combine it as the application name.
Nginx of a version earlier than 1.19 does not support manual configuration of environment variables. Therefore, the data source of the Nginx component configured on ServiceStage may be displayed as CCE on the Component Monitoring page of AOM. To solve this problem, use Nginx of 1.19 or a later version, manually configure environment variables such as CAS_COMPONENT_NAME and CAS_COMPONENT_ID.
- If the COMMAND value of a process is java, obtain the name of the JAR package in the command, the main class name in the command, and the first keyword that does not start with a hyphen (-) in the command based on the priorities in descending order as the component name, and use the default value unknownapplicationname as the application name.
- If the COMMAND value of a process is python, obtain the name of the first .py/.pyc script in the command as the component name, and use the default value unknownapplicationname as the application name.
- If the COMMAND value of a process is node, obtain the name of the first .js script in the command as the component name, and use the default value unknownapplicationname as the application name.
Custom Discovery Rules
The priorities of discovery rules are as follows: Sys_Rule > Custom discovery rules > Default_Rule. servicestage-default-rule is also a custom discovery rule.
- In the navigation pane, choose Configuration Management > Service Discovery.
- Click Add Custom Application Discovery Rule and configure an application discovery rule.
- Select a host for pre-detection.
- Customize a rule name, for example, ruletest.
- Select a typical host, for example, hhhhhh-27465, to check whether the application discovery rule is valid. The hosts that execute the rule will be configured in 6. Then, click Next.
- Set an application discovery rule.
- Click Add Check Items. AOM can discover processes that meet the conditions of check items.
For example, AOM can detect the processes whose command parameters contain ovs-vswitchd unix: and environment variables contain SUDO_USER=paas.
- To precisely detect processes, you are advised to add check items about unique features of the processes.
- You need to add one check item at least and can add five check items at most. If there are multiple check items, AOM only discovers the processes that meet the conditions of all check items.
- After adding check items, click Detect to search for the processes that meet the conditions.
If no process is detected within 20s, modify the discovery rule and detect processes again. Only when at least one process is detected, go to the next step.
- Set a component name.
- Set an application name.
In the Application Name Settings area, click Add Naming Rule to set an application name for the discovered process.
- If you do not set an application name, unknownapplicationname is used by default.
- When you add multiple naming rules, all the naming rules are combined as the application name of the process. Metrics with the same application name are aggregated.
In the Component Name Settings area, click Add Naming Rule to set a component name for the discovered process.
- The component name cannot be left blank.
- When you add multiple naming rules, all the naming rules are combined as the component name of the process. Metrics with the same component name are aggregated.
- Preview the component name.
If the application or component name does not meet your requirements, click
in the Preview Component Name table for renaming.
- Set a priority and detection range.
- Set a priority: When there are multiple rules, set priorities. Enter 1 to 9999. A smaller value indicates a higher priority. For example, 1 indicates the highest priority and 9999 indicates the lowest priority.
Do not use multiple custom discovery rules with the same priority for the same process.
- Set a detection range: Select a host to be detected. That is, select the host to which the configured rule is applied. If no host is selected, this rule will be executed on all hosts, including those added later.
- Click Add to complete the configuration. AOM collects metrics of the process.
- Wait for about two minutes, choose Monitoring > Component Monitoring in the navigation pane, select the hhhhhh-27465 host from the cluster drop-down list, and find out the /openvswitch/ component that has been monitored.
Custom discovery rules cannot be used to discover workload processes in the CCE scenario. You are advised to use custom discovery rules to discover non-workload processes in the CCE scenario or processes in the VM scenario.
More Operations
After creating an application discovery rule, you can also perform the operations described in Table 2.
Operation |
Description |
Viewing rule details |
In the Name column, click the name of an application discovery rule. |
Enabling or disabling a rule |
Deleting a rule |
Built-in application discovery rules cannot be deleted. |
Modifying a rule |
Click Modify in the Operation column. Built-in application discovery rules cannot be modified. |
