Anti-DDoS
Anti-DDoS
- What's New
- User Guide
- Best Practices
About Anti-DDoS
- What Is Anti-DDoS?
- What Are a SYN Flood Attack and an ACK Flood Attack?
- What Is a CC Attack?
- What Is a Slow HTTP Attack?
- What Are a UDP Attack and a TCP Attack?
- What Is the Million-level IP Address Blacklist Database?
- How Will Anti-DDoS Be Triggered to Scrub Traffic?
- Does Anti-DDoS Traffic Cleaning Affect Normal Services?
- How Does Anti-DDoS Scrub Traffic?
- What Are the Restrictions of Anti-DDoS?
- What Is the Protection Capacity of Anti-DDoS?
- What Data Can Be Provided by Anti-DDoS?
- In Which Regions Is Anti-DDoS Available?
- What Is the Maximum Protection Capacity Provided by HUAWEI CLOUD Anti-DDoS for Free?
- Which Services Can Use Anti-DDoS?
- Can Anti-DDoS Be Used Across Clouds?
- How to Determine Whether an Attack Occurs?
About Basic Functions
- What Are Regions and AZs?
- What Is the HTTP Request Threshold Set for Anti-DDoS Protection?
- What Would Happen When I Am Under a DDoS Attack Exceeding 500 Mbit/s?
- Which Types of Attacks Does Anti-DDoS Mitigate?
- What Should I Do If My Service Is Frequently Attacked?
- What Is the Difference Between ELB Protection and ECS Protection?
- Why Is the Number of Times of Cleaning Different from the Number of Attacks for the Same Public IP Address?
- Is Anti-DDoS Enabled by Default?
- Does Anti-DDoS Protect a Region or a Single IP Address?
- Do I Need to Clear the Resources of Anti-DDoS When I Delete an Account?
- How Do I View the Traffic Cleaning Frequency?
- How Can I View Anti-DDoS Protection Statistics?
- How Can I View Public IP Address Monitoring Data in Anti-DDoS?
- How Can I View an Interception Report?
- Can I Disable Anti-DDoS Completely?
- How Do I Check Whether the Inbound Traffics Are Routed Through Anti-DDoS Devices?
- About Threshold and Black Hole
- About Alarm notification
- Change History
About Anti-DDoS
- Glossary
More Documents
- Viewing a Public IP Address
- Enabling Alarm Notification
- Configuring an Anti-DDoS Protection Policy
- Viewing a Monitoring Report
- Viewing an Interception Report
About Anti-DDoS
- About Basic Functions
About Anti-DDoS
- Change History
- Before You Start
- API Overview
- API Calling
API
Anti-DDoS APIs
- Querying Optional Anti-DDoS Defense Policies
- Querying Configured Anti-DDoS Defense Policies
- Updating Anti-DDoS Defense Policies
- Querying Anti-DDoS Tasks
- Querying the List of Defense Statuses of EIPs
- Querying the Defense Status of a Specified EIP
- Querying the Traffic of a Specified EIP
- Querying Events of a Specified EIP
- Querying Weekly Defense Statistics
- Alarm Reminding APIs
Anti-DDoS APIs
- Appendix
- Change History
About Anti-DDoS
About Anti-DDoS
- Change History
- Before You Start
- API Overview
- API Calling
API
DDoS Protection Management
- Querying Anti-DDoS specifications
- Enabling Anti-DDoS
- Anti-DDoS Task Management
- Alarm Configuration Management
- Status Code
- Anti-DDoS Error Codes
- Obtaining a Project ID
- Change History
User Guide (Ankara Region)
About Anti-DDoS
About Anti-DDoS
- Change History
API Reference (Ankara Region)
- Before You Start
- API Overview
- API Calling
API
Anti-DDoS APIs
Anti-DDoS APIs
- Appendix
- Change History
On this page
Show all
Help Center/
Anti-DDoS/
User Guide (ME-Abu Dhabi Region) /
FAQs/
About Alarm notification/
Will I Be Promptly Notified When an Attack Is Detected?
Yes, if you enable alarm notification.
On the console, click the Alarm Notifications tab to enable the alarm notification function, which enables you to receive alarms through the endpoint you have configured if a DDoS attack is detected. For details, see Enabling Alarm Notification.
Parent topic: About Alarm notification
