Anti-DDoS
Anti-DDoS
- What's New
- User Guide
- Best Practices
About Anti-DDoS
- What Is Anti-DDoS?
- What Are a SYN Flood Attack and an ACK Flood Attack?
- What Is a CC Attack?
- What Is a Slow HTTP Attack?
- What Are a UDP Attack and a TCP Attack?
- What Is the Million-level IP Address Blacklist Database?
- How Will Anti-DDoS Be Triggered to Scrub Traffic?
- Does Anti-DDoS Traffic Cleaning Affect Normal Services?
- How Does Anti-DDoS Scrub Traffic?
- What Are the Restrictions of Anti-DDoS?
- What Is the Protection Capacity of Anti-DDoS?
- What Data Can Be Provided by Anti-DDoS?
- In Which Regions Is Anti-DDoS Available?
- What Is the Maximum Protection Capacity Provided by HUAWEI CLOUD Anti-DDoS for Free?
- Which Services Can Use Anti-DDoS?
- Can Anti-DDoS Be Used Across Clouds?
- How to Determine Whether an Attack Occurs?
About Basic Functions
- What Are Regions and AZs?
- What Is the HTTP Request Threshold Set for Anti-DDoS Protection?
- What Would Happen When I Am Under a DDoS Attack Exceeding 500 Mbit/s?
- Which Types of Attacks Does Anti-DDoS Mitigate?
- What Should I Do If My Service Is Frequently Attacked?
- What Is the Difference Between ELB Protection and ECS Protection?
- Why Is the Number of Times of Cleaning Different from the Number of Attacks for the Same Public IP Address?
- Is Anti-DDoS Enabled by Default?
- Does Anti-DDoS Protect a Region or a Single IP Address?
- Do I Need to Clear the Resources of Anti-DDoS When I Delete an Account?
- How Do I View the Traffic Cleaning Frequency?
- How Can I View Anti-DDoS Protection Statistics?
- How Can I View Public IP Address Monitoring Data in Anti-DDoS?
- How Can I View an Interception Report?
- Can I Disable Anti-DDoS Completely?
- How Do I Check Whether the Inbound Traffics Are Routed Through Anti-DDoS Devices?
- About Threshold and Black Hole
- About Alarm notification
- Change History
About Anti-DDoS
- Glossary
More Documents
- Viewing a Public IP Address
- Enabling Alarm Notification
- Configuring an Anti-DDoS Protection Policy
- Viewing a Monitoring Report
- Viewing an Interception Report
About Anti-DDoS
- About Basic Functions
About Anti-DDoS
- Change History
- Before You Start
- API Overview
- API Calling
API
Anti-DDoS APIs
- Querying Optional Anti-DDoS Defense Policies
- Querying Configured Anti-DDoS Defense Policies
- Updating Anti-DDoS Defense Policies
- Querying Anti-DDoS Tasks
- Querying the List of Defense Statuses of EIPs
- Querying the Defense Status of a Specified EIP
- Querying the Traffic of a Specified EIP
- Querying Events of a Specified EIP
- Querying Weekly Defense Statistics
- Alarm Reminding APIs
Anti-DDoS APIs
- Appendix
- Change History
About Anti-DDoS
About Anti-DDoS
- Change History
- Before You Start
- API Overview
- API Calling
API
DDoS Protection Management
- Querying Anti-DDoS specifications
- Enabling Anti-DDoS
- Anti-DDoS Task Management
- Alarm Configuration Management
- Status Code
- Anti-DDoS Error Codes
- Obtaining a Project ID
- Change History
User Guide (Ankara Region)
About Anti-DDoS
About Anti-DDoS
- Change History
API Reference (Ankara Region)
- Before You Start
- API Overview
- API Calling
API
Anti-DDoS APIs
Anti-DDoS APIs
- Appendix
- Change History
On this page
Show all
Help Center/
Anti-DDoS/
User Guide (ME-Abu Dhabi Region) /
FAQs/
About Basic Functions/
Anti-DDoS helps users mitigate the following attacks:
- Web server attacks
Include SYN flood, HTTP flood, Challenge Collapsar (CC), and low-rate attacks
- Game attacks
Include UDP flood, SYN flood, TCP-based, and fragmentation attacks
- HTTPS server attacks
- DNS server attacks
Include attacks exploiting DNS protocol stack vulnerabilities, DNS reflection attacks, DNS flood attacks, and DNS cache miss attacks
Parent topic: About Basic Functions
