Anti-DDoS
Anti-DDoS
- What's New
- User Guide
- Best Practices
About Anti-DDoS
- What Is Anti-DDoS?
- What Are a SYN Flood Attack and an ACK Flood Attack?
- What Is a CC Attack?
- What Is a Slow HTTP Attack?
- What Are a UDP Attack and a TCP Attack?
- What Is the Million-level IP Address Blacklist Database?
- How Will Anti-DDoS Be Triggered to Scrub Traffic?
- Does Anti-DDoS Traffic Cleaning Affect Normal Services?
- How Does Anti-DDoS Scrub Traffic?
- What Are the Restrictions of Anti-DDoS?
- What Is the Protection Capacity of Anti-DDoS?
- What Data Can Be Provided by Anti-DDoS?
- In Which Regions Is Anti-DDoS Available?
- What Is the Maximum Protection Capacity Provided by HUAWEI CLOUD Anti-DDoS for Free?
- Which Services Can Use Anti-DDoS?
- Can Anti-DDoS Be Used Across Clouds?
- How to Determine Whether an Attack Occurs?
About Basic Functions
- What Are Regions and AZs?
- What Is the HTTP Request Threshold Set for Anti-DDoS Protection?
- What Would Happen When I Am Under a DDoS Attack Exceeding 500 Mbit/s?
- Which Types of Attacks Does Anti-DDoS Mitigate?
- What Should I Do If My Service Is Frequently Attacked?
- What Is the Difference Between ELB Protection and ECS Protection?
- Why Is the Number of Times of Cleaning Different from the Number of Attacks for the Same Public IP Address?
- Is Anti-DDoS Enabled by Default?
- Does Anti-DDoS Protect a Region or a Single IP Address?
- Do I Need to Clear the Resources of Anti-DDoS When I Delete an Account?
- How Do I View the Traffic Cleaning Frequency?
- How Can I View Anti-DDoS Protection Statistics?
- How Can I View Public IP Address Monitoring Data in Anti-DDoS?
- How Can I View an Interception Report?
- Can I Disable Anti-DDoS Completely?
- How Do I Check Whether the Inbound Traffics Are Routed Through Anti-DDoS Devices?
- About Threshold and Black Hole
- About Alarm notification
- Change History
About Anti-DDoS
- Glossary
More Documents
- Viewing a Public IP Address
- Enabling Alarm Notification
- Configuring an Anti-DDoS Protection Policy
- Viewing a Monitoring Report
- Viewing an Interception Report
About Anti-DDoS
- About Basic Functions
About Anti-DDoS
- Change History
- Before You Start
- API Overview
- API Calling
API
Anti-DDoS APIs
- Querying Optional Anti-DDoS Defense Policies
- Querying Configured Anti-DDoS Defense Policies
- Updating Anti-DDoS Defense Policies
- Querying Anti-DDoS Tasks
- Querying the List of Defense Statuses of EIPs
- Querying the Defense Status of a Specified EIP
- Querying the Traffic of a Specified EIP
- Querying Events of a Specified EIP
- Querying Weekly Defense Statistics
- Alarm Reminding APIs
Anti-DDoS APIs
- Appendix
- Change History
About Anti-DDoS
About Anti-DDoS
- Change History
- Before You Start
- API Overview
- API Calling
API
DDoS Protection Management
- Querying Anti-DDoS specifications
- Enabling Anti-DDoS
- Anti-DDoS Task Management
- Alarm Configuration Management
- Status Code
- Anti-DDoS Error Codes
- Obtaining a Project ID
- Change History
User Guide (Ankara Region)
About Anti-DDoS
About Anti-DDoS
- Change History
API Reference (Ankara Region)
- Before You Start
- API Overview
- API Calling
API
Anti-DDoS APIs
Anti-DDoS APIs
- Appendix
- Change History
On this page
Show all
This section describes how to view the monitoring report of a public IP address. This report includes the protection status, protection settings, and the last 24 hours' traffic and anomalies.
You have obtained a username and password for logging in to the management console.
- Click
in the upper left corner of the management console and select the region and project.
- Click
. Under Security, choose Anti-DDoS.
- Click the Public IP Addresses tab, locate the row that contains the IP address of which you want to view its monitoring report, and click View Monitoring Report.
Figure 1 Viewing a monitoring report
- On the Monitoring Report page, view monitoring details about the public IP address.
- You can view information such as the current defense status, current defense configurations, traffic within 24 hours, and abnormalities within 24 hours.
- A 24-hour defense traffic chart is generated from data points taken in five-minute intervals. It includes the following information:
- Traffic displays the traffic status of the selected ECS, including the incoming attack traffic and normal traffic.
- Packet Rate displays the packet rate of the selected ECS, including the attack packet rate and normal incoming packet rate.
- The attack event list within one day records DDoS attacks on the ECS within one day, including cleaning events and black hole events.
Figure 2 Viewing a traffic monitoring reportFigure 3 Viewing a packet rate monitoring reportNOTE:
- Click
to download monitoring reports to view monitoring details about the public IP address.
- On the traffic monitoring report page, click
or
to view details about the Inbound attack traffic or Inbound normal traffic.
- On the packet rate monitoring report page, click
or
to view details about the Inbound attack packet rate and Inbound normal packet rate.
