Updated on 2025-02-06 GMT+08:00
Querying VPC Flow Logs
Function
This API is used to query all VPC flow logs of the tenant submitting the request. The VPC flow logs are filtered based on the filtering condition.
URI
GET /v1/{project_id}/fl/flow_logs
Example:
GET https://{Endpoint}/v1/b2782e6708b8475c993e6064bc456bf8/fl/flow_logs?name=flowlog
Table 1 describes the parameters.
Table 1 Parameter description
Mandatory
Type
project_id
Yes
String
id
No
String
  • Flow log ID
name
No
String
  • Flow log name
  • The value can contain up to 64 characters, including letters, digits, underscores (_), hyphens (-), and periods (.).
tenant_id
No
String
  • Project ID
description
No
String
  • Flow log description
  • The value can contain no more than 255 characters and cannot contain angle brackets (< or >).
resource_type
No
String
  • Type of the resource for which that the logs to be collected.
  • The value can be:
    • port: a single network interface.
    • vpc: All network interfaces in a VPC.
    • network: All network interfaces in a subnet.
resource_id
No
String
  • ID of the resource for which that the logs to be collected.
traffic_type
No
String
  • Type of the traffic for which that the logs to be collected.
  • The value can be:
    • all: specifies that both accepted and rejected traffic of the specified resource will be logged.
    • accept: specifies that only accepted inbound and outbound traffic of the specified resource will be logged.
    • reject: specifies that only rejected inbound and outbound traffic of the specified resource will be logged.
log_group_id
No
String
  • Log group ID
log_topic_id
No
String
  • Log topic ID
limit
No
Integer
Specifies the number of records that will be returned on each page. The value is from 0 to intmax (2^31-1). The default value is 2000.
limit can be used together with marker. For details, see the parameter description of marker.
marker
No
String
Specifies a resource ID for pagination query, indicating that the query starts from the next record of the specified resource ID.
This parameter can work together with the parameter limit.
  • If parameters marker and limit are not passed, resource records on the first page will be returned.
  • If the parameter marker is not passed and the value of parameter limit is set to 10, the first 10 resource records will be returned.
  • If the value of the parameter marker is set to the resource ID of the 10th record and the value of parameter limit is set to 10, the 11th to 20th resource records will be returned.
  • If the value of the parameter marker is set to the resource ID of the 10th record and the parameter limit is not passed, 11th to 2,000th resource records will be returned. The default value of limit is 2000.
Request Parameters
None
Example Request
Response Parameters
Table 2 Response parameter
Type
flow_logs
Array of FlowLog objects
FlowLog object list. For details, see Table 3.
Table 3 Description of the FlowLog field
Type
id
String
  • Flow log ID
name
String
  • Flow log name
tenant_id
String
  • Project ID
description
String
resource_type
String
  • The value can be:
resource_id
String
traffic_type
String
  • The value can be:
log_group_id
String
  • Log group ID
log_topic_id
String
  • Log topic ID
created_at
String
  • Time when the flow log is created
  • UTC time in the format of yyyy-MM-ddTHH:mm:ss
updated_at
String
  • Time when the flow log is updated
Example Response
    "flow_logs": [
            "id": "35868d55-443e-4d5c-90a4-ac618dc45c1a",
            "name": "flowlog",
            "description": "just a test",
            "tenant_id": "b2782e6708b8475c993e6064bc456bf8",
            "resource_type": "port",
            "resource_id": "05c4052d-8d14-488f-aa00-19fea5a25fde",
            "traffic_type": "reject",
            "log_group_id": "05c4052d-8d14-488f-aa00-19fea5a25fff",
            "log_topic_id": "a9d7dee7-37d2-4cba-a208-a016252aaa63",
            "created_at": "2019-01-14T11:03:02",
            "updated_at": "2019-01-14T11:03:02"
Status Code
See Status Codes.
Error Code
See Error Codes.
