Creating a VPC Flow Log
Function
This API is used to create a VPC flow log.
A VPC flow log captures information about the traffic going to and from your VPC. You can use flow logs to monitor network traffic, analyze network attacks, and to determine whether security group and network ACL rules need to be modified.
VPC flow logs must be used together with the Log Tank Service (LTS). You need to create a log group and a log topic in LTS, and then create a VPC flow log.
URI
POST /v1/{project_id}/fl/flow_logs
Table 1 describes the parameters.
Parameter |
Mandatory |
Type |
Description |
project_id |
Yes |
String |
Project ID. For details about how to obtain a project ID, see Obtaining a Project ID. |
Request Parameters
Parameter |
Mandatory |
Type |
Description |
flow_log |
Yes |
flow_log object |
FlowLog objects. For details, see Table 3. |
Parameter |
Mandatory |
Type |
Description |
name |
No |
String |
description |
No |
String |
resource_type |
Yes |
String |
resource_id |
Yes |
String |
traffic_type |
Yes |
String |
log_group_id |
Yes |
String |
log_topic_id |
Yes |
String |
Example Request
- Create a VPC flow log. Set the resource type to port, resource ID to 05c4052d-8d14-488f-aa00-19fea5a25fde, traffic type to reject, log group ID to 05c4052d-8d14-488f-aa00-19fea5a25fdd, and log topic ID to a9d7dee7-37d2-4cba-a208-a016252aaa63.
POST https://{Endpoint}/v1/b2782e6708b8475c993e6064bc456bf8/fl/flow_logs { "flow_log": { "name": "flowlog", "description": "just a test", "resource_type": "port", "resource_id": "05c4052d-8d14-488f-aa00-19fea5a25fde", "traffic_type": "reject", "log_group_id": "05c4052d-8d14-488f-aa00-19fea5a25fdd", "log_topic_id": "a9d7dee7-37d2-4cba-a208-a016252aaa63" } }
Response Parameters
Parameter |
Type |
Description |
flow_log |
flow_log object |
FlowLog objects. For details, see Table 5. |
Parameter |
Type |
Description |
id |
String |
name |
String |
tenant_id |
String |
description |
String |
resource_type |
String |
resource_id |
String |
traffic_type |
String |
log_group_id |
String |
log_topic_id |
String |
created_at |
String |
updated_at |
String |
Example Response
{ "flow_log": { "id": "f49f00f1-0f15-470a-a8c5-4e879e461c8d", "name": "flowlog", "description": "just a test", "tenant_id": "b2782e6708b8475c993e6064bc456bf8", "resource_type": "port", "resource_id": "05c4052d-8d14-488f-aa00-19fea5a25fde", "traffic_type": "reject", "log_group_id": "05c4052d-8d14-488f-aa00-19fea5a25fdd", "log_topic_id": "a9d7dee7-37d2-4cba-a208-a016252aaa63", "created_at": "2019-01-14T11:03:02", "updated_at": "2019-01-14T11:03:02" } }
Status Code
See Status Codes.
Error Code
See Error Codes.
