Updated on 2025-08-27 GMT+08:00
Managing VPC Tags
Tags help you identify, classify, and search for VPCs. You can perform the following operations to manage VPC tags:
  • Add tags to a VPC.
  • Modify a VPC tag.
  • Delete a VPC tag.
If your organization has configured tag policies for VPCs, you need to add tags to your VPCs based on the policies. If you add a tag that does not comply with the tag policies, VPCs may fail to be created. Contact your administrator to learn more about tag policies.
For details about VPC tag requirements, see Table 1.
Table 1 VPC tag key and value requirements
Requirements
Example Value
Key
  • For each resource, each tag key must be unique, and each tag key can only have one tag value.
  • Cannot be left blank.
  • Can contain a maximum of 128 characters.
  • Cannot start or end with a space.
vpc_key1
Value
  • Can be left blank.
  • Can contain a maximum of 255 characters.
vpc-01
Notes and Constraints
Each cloud resource can have a maximum of 20 tags.
  1. Go to the VPC list page.
  2. In the VPC list, locate the target VPC and click its name.
    The VPC details page is displayed.
  3. On the Tags tab, click Edit Tag in the upper left corner above the tag list.
    The Edit Tag dialog box is displayed.
  4. Perform the following operations on the tag as required:
    • Adding a tag: Click , enter a tag key and value, and click OK.
    • Modifying a tag: Click next to the target tag key or value, delete the original value, enter a new value, and click OK.
    • Deleting a tag: Click Delete next to the target tag and click OK.
