Help Center/ CodeArts Pipeline/ User Guide/ Managing Pipeline Extensions/ Creating an Extension by Uploading an Extension Package
Updated on 2025-08-13 GMT+08:00
You can create and configure a pipeline extension by writing code for better flexibility and maintainability.
Preparing an Extension Package
Extension package
Notes
  • The extension package must be in the ZIP format.
  • The root directory of the package must contain a metadata file codearts-extension.json. For more information about the file, see codearts-extension.json.
  • The resources.json file can be encoded only using UTF-8.
File structure
extension.zip                          # ZIP package of the extension
   | -- scripts                        # (Optional) Script folder for storing scripts that contain extension execution logic.
   |    | -- xxx                       # Script that contains extension execution logic
   | -- i18n                           # (Optional) Contents in multiple languages
   |    | -- zh-cn                     # Contents in Chinese environment
   |         | -- resource.json       # Internationalization resources
   |    | -- en-us                     # Contents in English environment
   |         | -- resources.json       # Internationalization resources
   | -- codearts-extension.json        # (Mandatory) Extension execution file (in JSON format), including basic information, inputs, and execution
  1. Access the CodeArts Pipeline homepage.
  2. On the CodeArts Pipeline homepage, choose Services > Extensions.
  3. Click .
  4. Set basic information. For details, see Table 1.
    Table 1 Extension information
    Icon
    Icon of the extension. Upload an image in PNG, JPEG, or JPG format, with a file size no more than 512 KB (recommended: 128 x 128 pixels). If no image is uploaded, the system generates an icon.
    Name
    The extension name displayed in the extension platform. Enter only spaces, letters, digits, underscores (_), hyphens (-), and periods (.) with a maximum of 50 characters.
    Unique Identifier
    ID of the extension. This value should be consistent with the name field of the codearts-extension.json file. Once set, this parameter cannot be changed. Enter only letters, digits, underscores (_), and hyphens (-) with a maximum of 50 characters.
    Mapping between the extension type and the value of category:
    • Build: Build
    • Check: Gate
    • Deploy: Deploy
    • Test: Test
    • Normal: Normal
    Type
    Type of the extension, which can be Build, Check, Test, Deploy, or Normal. Once set, this parameter cannot be changed.
    Purposes and functions of the extension. The description can be edited. Enter no more than 1,000 characters.
  5. Click Next. The version management page is displayed.
  6. On the displayed page, click . In the displayed dialog box, select the desired extension (with input definition and execution script) and upload it. After the upload is successful, the version will be marked with Draft.
    Figure 1 Uploading an extension
  7. Using an extension in a pipeline
    Create a pipeline. On the Task Orchestration page, create a job, add the registered basic extension, and set parameters.
  8. Click Save and Execute. After the execution is complete, click the extension name to view the execution result.
  9. (Optional) After debugging, publish the extension as an official version.
    1. Go to the extension page.
    2. Click the registered basic extension.
    3. On the displayed page, click on the right to publish the version as an official version.
    The draft version can be overwritten for multiple times. However, the official version cannot be updated. You can click Upload plug-in in the upper right corner to upload a new version.
Example:
    "type": "Task",
    "name": "demo_plugin",
	"friendlyName": "Extension name",
	"description": "This is an extension.",
    "category": "Gate",
    "version": "0.0.2",
	"versionDescription": "Updated based on the initial version 0.0.1",
    "dataSourceBindings": [],
    "inputs": [
	"name": "samplestring",                              # Use ${samplestring} in a script to obtain the value configured by an executor in a pipeline
	"type": "input",                                     # Different types correspond to different functions
	"description": "Sample String",                      # Description of input
	"defaultValue": "00",                                # Default value when the value of the required field is false
	"required": true,                                    # Reset defaultValue if the required field is true, or the default value will be used
            "label": "Text box",                                # input information displayed on the pipeline editing page
            "validation": {
                "requiredMessage": "Enter a value",                    # (Optional) The message displayed when the required field is left blank
                "regex": "^[a-zA-Z0-9-_\\u4e00-\\u9fa5]{1,32}$", #(Optional) RegEx validation
                "regexMessage": "Type error"                       # (Optional) The message displayed when RegEx validation failed
    "execution": {
        "type": "Shell",
        "target": "scripts/execution.sh"
    "outputs": [{
			"name": "okey",                          # Output name.
			"type": "output",                        # Output type: output or metrics.
			"description": "Description",
			"prop": {
				"defaultValue": "123"            # Default value
			"name": "mkey",
			"type": "metrics",
			"description": "description",                   # Description of output
			"prop": {
				"defaultValue": "213",
				"group": "213"                   # Corresponding to the group name in pass conditions			}
The parameters of codearts-extension.json are described in the following table.
Table 2 Parameters
type
The value is fixed to Task, which indicates an extension type.
name
Same as the Unique Identifier field set for extension registration
friendlyName
Same as the Name field set for extension registration
category
Same as the Type field set for extension registration, which can be:
  • Build: corresponds to the extension of the Build type.
  • Test: corresponds to the extension of the Test type.
  • Gate: corresponds to the extension of the Check type.
  • Normal: corresponds to the extension of the Normal type.
  • Deploy: corresponds to the extension of the Deploy type.
version
Version of the extension, which consists of three numbers separated by dots (.), with each number ranges from 0 to 99. Modify this parameter only when you need to add an official version.
description
Description of the extension.
versionDescription
Description of the extension version's unique features.
dataSourceBindings
Disabled currently. Set it to [].
inputs
Extension input content. This parameter corresponds to the extension display format on the pipeline page. The values can be referenced by environment variables in service scripts.
execution
Extension execution content. The type field indicates the service script language, and the target field indicates the path to the execution file. You are advised to create a scripts folder and place the content under it.
outputs
Extension output content. The value can be used as the gate metrics. output has different display. output is used in the pipeline context. The output content can be used in subsequent stages or displayed in the task execution result. metrics data is used to create pass rules. For details, see Table 6.
Supported inputs are listed in the following table.
Table 3 inputs
Type
Widget
Example
extendProp
input
Single-line Text Box
  • visibleConditions
  • disabledConditions
inputNumber
Digit
  • visibleConditions
switch
Switch
  • visibleConditions
singleSelect
Single-selection Drop-down List
  • options
  • apiType
  • apiOptions
multipleSelect
Multi-selection Drop-down List
  • options
  • apiType
  • apiOptions
keyValuePair
Key-Value Pair
  • visibleConditions
radio
Option Button
options
timeInterval
Time Interval
  • visibleConditions
shell
Shell
  • visibleConditions
endpoint:${module_id}
Endpoint
  • visibleConditions
inputs fields are listed in the following table.
Table 4 inputs fields
Field
Mandatory
Remarks
name
Unique ID of the widget
Yes
The value must be unique.
label
Widget title
Yes
type
Widget type
Yes
defaultValue
Initial value
No
Initial default value of a widget. This field can be left blank.
description
Widget description
No
The infotip message next to a widget name
required
Whether a parameter is mandatory.
No
Fields marked with asterisks (*) are mandatory.
validation
Validation information, which is an object that contains the requiredMessage, regex, and regexMessage properties.
    requiredMessage: '',    // Prompt message for a mandatory field
    regex: '',              //  RegEx validation
    regexMessage: ''        // The message displayed when RegEx validation failed
No
extendProp
Extension field
     visibleConditions: [],
     disabledConditions: []
No
For details about extendProp, see Table 5.
extendProp functions are listed in the following table.
Table 5 extendProp functions
Field
Mandatory
Remarks
visibleConditions
Widgets are displayed if conditions are met.
No
Multiple conditions can be included:
Example:
[{comp:'key_001',symbol:'===', value: 'xxx'}]
In this example, widget A will be displayed if widget B has a unique ID of key_001 and has a value that is equal to (===) xxx.
symbol can be:
  • ===: Equal
  • !==: Not equal
  • empty: Empty
  • notEmpty: Not empty
disabledConditions
Widgets are disabled if conditions are met.
No
Example:
[{comp:'key_002',symbol:'!==', value: 'yyy'}]
In this example, widget A will be disabled if widget B has a unique ID of key_002 and has a value that is not equal to (!==) yyy.
symbol can be:
  • ===: Equal
  • !==: Not equal
  • empty: Empty
options
The fixed drop-down list. The field's type is list.
No
Example:
[{label:'option 1',value: 1},{label:'option 2',value: 2}]
apiType
Options in the drop-down list box:
  • fixed: The values in options are used as options.
  • api: API requests, available only when apiOptions is configured.
No
If this field is left blank, fixed is used.
apiOptions
JSON body, including parameters used by APIs.
No
Example:
'{"body":{"xxx":111},"header":{"yyy":222},"linkedFields":["key_001"],"method":"POST","params":{"zzz":333},"remote":true,"remoteName":"xxx","remoteQueryField":"body","responseUrl":"data","label":"name","value":"id","url":"https://sss/lll/mmm"}'
JSON (parsed):
    body: {xxx:111},             // Request parameters for calling an API
    header: {yyy: 222},          // Request header field
    params: {zzz: 333},          // Request parameters for calling an API
    linkedFields: ['key_001],    // This field is associated with other widgets. When the values of other widgets change, the API will be called again and the current options will be cleared.
    method: 'POST',              // Request mode: POST or GET
    remote: true,                // Whether to enable remote search
    remoteName: 'tt',            // Field to be searched in a remote search
    remoteQueryField: 'body',    // Parameter passing method for the remote search field: body or params
    responseUrl: 'data',         // The path of the option list obtained in the returned data
    label: 'name',               // Parameter corresponding to the label in ComboBox
    value: 'id',                 // Parameter corresponding to the actual value in ComboBox
    url: 'https://sss/lll/mmm'   // API URL
outputs fields are listed in the following table.
Table 6 outputs fields
Field
Mandatory
Remarks
name
Output name.
Yes
type
Output type.
  • output: displayed on the Others card and used in pipeline contexts.
  • metrics: displayed on the Others card. It outputs metric thresholds. The thresholds information can be referenced in the extension and finally applied to pipelines. For details, see Configuring a Rule.
  • link: displayed on the Link card. You can click the link to go to the corresponding page.
  • table: displayed on the Tabular Data page. It is an object array and displays the array information in a table.
Yes
description
Description of the value. This parameter is mandatory when type is set to metrics.
prop
When type is set to metrics, group corresponds to the group name in pass rules and this parameter is mandatory.
