Help Center/ CodeArts Pipeline/ User Guide/ CodeArts Release User Guide/ Checking the Environment Release Result
Updated on 2025-03-21 GMT+08:00
  1. Access the release environment list page.
  2. Click an environment name. The Environment Information page is displayed.
  3. On the displayed page, click the Deployment History tab.
  4. Click a service ticket name to check details. The details page displays the information of release flow, atomic extension, and some basic information.
    • Release flow
      • Release flow displays information such as the execution result, service ticket type, executor, pipeline, and release policy. You can click an atomic extension to check its details.
      • Cancel: You can click Cancel to cancel the release.
      • Retry: If the release fails or the release is canceled, you can click Retry to retry the release.
      • Rollback: Click Rollback. In the displayed dialog box, if you confirm the rollback, the release will be canceled and the service state will be restored to its pre-release state.
        When the environment is directly released, the pipeline information is not displayed in the deployment ticket.
        Rollback can be performed anytime. If the current deployment version does not meet your expectation, you can quickly restore the environment to the previous one through rollback.
    • Basic information
      Basic information includes environment name, policy, service endpoint, variable version, image, start time, and end time.
    • Atomic extension release
      The release detail of atomic extension is displayed. You can click to refresh the details.
      Figure 1 Atomic extension release
      Table 1 Atomic extension release
      Extension
      Release Information
      Rolling upgrade
      The details page displays the workload to be upgraded, instance information, and key event.
      • Workload
        Workload name, type, namespace, and creation time
      • Instance information
        Instance name, status, pod IP address, host IP address (IP address of the node where the pod is located), and creation time.
      • Key event
        K8s component name, event type, K8s event, first occurrence time, and recent occurrence time. Key event information can help you locate pod faults.
      Start workload
      The details page displays workload to be upgraded, pod information, and key event. You can click the version cards to check the previous or the current workload information.
      • Workload
        Previous workload name, current workload name, type, and namespace
      • Key event
      Divert traffic
      The details page displays the service name, old version number, new version number, and namespace.
      Remove old version
      The details page displays the workload name, workload type, and namespace.
      Manual check
      The details page displays check duration, operation time, description, and status.
