Updated on 2026-11-02 GMT+08:00
Analyzing a Folder
You can use Folder Analysis to calculate the size of a folder and the number of objects in a folder.
If you use Folder Analysis to calculate the size of a folder, you will be billed for the API calls used to list objects in the bucket. For details, see Billing Description.
  • Only folders with no more than 1 million objects can be analyzed. If your folder contains more objects than that, use the listing objects command of obsutil for analysis.
  • It may take some time to analyze folders with a lot of objects.
  • After versioning is enabled, OBS Console can display only the number and size of current objects. It does not provide the number or size of historical versions.
Ways to Use Folder Analysis
You can analyze a folder using OBS Console or obsutil, but not using APIs, SDKs, or OBS Browser+.
