Updated on 2026-11-02 GMT+08:00
Replicating Bucket Policies
OBS allows you to replicate an existing bucket policy to a new bucket. When replicating policies, OBS automatically replaces the bucket name in the source bucket policies with the destination bucket name, for the policies to apply to the destination bucket.
  • The policies replicated from a source bucket will not overwrite existing policies in the destination bucket.
  • The source policies with the same name as those in the destination bucket will not be replicated.
  • Both source and destination buckets must be of the 3.0 version.
  1. In the navigation pane of OBS Console, choose Buckets.
  2. In the bucket list, click the desired bucket. The Objects page is displayed.
  3. In the navigation pane, choose Permissions > Bucket Policies.
  4. Click Replicate.
  5. Select a replication source, which is the bucket whose policies you want to replicate.
    After you select a replication source, all bucket policies whose names differ from those in the destination bucket are displayed. You can remove any that are not required.
    Figure 1 Replicating bucket policies
  6. Click OK to replicate the bucket policies to the destination bucket.
