Creating a Bucket Policy with a Template
OBS Console offers bucket policy templates for common scenarios. You can use the templates to quickly configure bucket policies.
Ways to Configure Bucket Policies
You can use templates to create bucket policies using OBS Console, but not using APIs, SDKs, OBS Browser+, or obsutil.
Using OBS Console
- In the navigation pane of OBS Console, choose Buckets.
- In the bucket list, click the desired bucket. The Objects page is displayed.
- In the navigation pane, choose Permissions > Bucket Policies.
- Click Create.
- Choose a policy template. For details about the parameters, see Bucket Policies.
Table 1 Bucket policy templates Principal
Resource
Template
Actions Allowed
Advanced Settings
All accounts
Entire bucket (including the objects in it)
Public Read
See Figure 1.
Allows anonymous users to perform the following actions on a bucket and the objects in it:
HeadBucket (to check whether the bucket exists and obtain the bucket metadata)
GetBucketLocation (to get the bucket location)
GetObject (to obtain object content and metadata)
RestoreObject (to restore Archive objects)
GetObjectVersion (to obtain the content and metadata of a specified object version)
Excluding the specified actions is not allowed.
Public Read/Write
See Figure 2.
ListBucket (to list objects in the bucket and obtain the bucket metadata)
ListBucketVersions (to list object versions in the bucket)
PutObject (to upload objects using PUT and POST, upload parts, initiate multipart uploads, and assemble parts)
ModifyObjectMetaData (to modify object metadata)
ListBucketMultipartUploads (to list multipart uploads)
ListMultipartUploadParts (to list uploaded parts)
AbortMultipartUpload (to abort multipart uploads)
PutObjectAcl (to configure the object ACL)
GetObjectVersionAcl (to obtain the ACL of a specified object version)
GetObjectAcl (to obtain the object ACL)
Current account/Other accounts/Delegated accounts
Bucket Read-Only
See Figure 3.
Allows specified accounts to perform the following actions on a bucket and the objects in it:
Get* (all GET actions)
List* (all LIST actions)
Bucket Read/Write
See Figure 4.
Allows specified accounts to perform all actions excluding the following ones on a bucket and the objects in it:
DeleteBucket (to delete the bucket)
PutBucketPolicy (to configure a bucket policy)
PutBucketAcl (to configure the bucket ACL)
Excluding the specified actions is allowed.
All accounts/Current account/Other accounts/Delegated accounts
Current bucket + Specified objects
Directory Read-Only
See Figure 5.
Allows all accounts or specified accounts to perform the following actions on the current bucket and the specified resources in it:
ListBucket (to list objects in the bucket and obtain the bucket metadata). This action is not included in the template if you apply the policy to All accounts.
ListBucketVersions (to list object versions in the bucket). This action is not included in the template if you apply the policy to All accounts.
Directory Read/Write
See Figure 6.
Specified objects
Object Read-Only
See Figure 7.
Allows all accounts or specified accounts to perform the following actions on specified resources in the bucket:
Object Read/Write
See Figure 8.
GetObjectVersionAcl (to obtain the ACL of an object version)
- Complete the bucket policy configuration.
Some bucket policy templates require a configuration of principals or resources. You can also change the existing settings of a template, including the policy name, principals, resources, actions, and conditions. For details, see Bucket Policy Parameters.
- Click Create in the lower right corner.
