Updated on 2026-01-19 GMT+08:00
Creating a Custom Bucket Policy (Visual Editor)
You can customize bucket policies based on your needs. A custom bucket policy consists of five basic elements: effects, principals, resources, actions, and conditions. For details, see Bucket Policy Parameters.
  1. In the navigation pane of OBS Console, choose Buckets.
  2. In the bucket list, click the bucket you want to operate. The Objects page is displayed.
  3. In the navigation pane, choose Permissions > Bucket Policies.
  4. Click Create.
  5. Configure a bucket policy.
    Figure 1 Configuring a bucket policy
    Table 1 Parameters for configuring a custom bucket policy
    Configuration method
    Visual editor or JSON. The visual editor is used here. For details about configurations in the JSON view, see Creating a Custom Bucket Policy (JSON View).
    Policy Name
    Enter a bucket policy name.
    Effect
    • Allow: The policy allows the matched requests.
    • Deny: The policy denies the matched requests.
    Principal
    • All accounts: The bucket policy applies to anonymous users.
    • Current account: Specify one or more IAM users under the current account.
    • Other accounts: Specify one or more accounts.
      The account ID and IAM user ID can be obtained from the My Credentials page.
      The format is Account ID/IAM User ID. To specify multiple accounts, enter each one on a separate line.
      Account ID/* indicates that permission is granted to all users under the account.
      Delegated accounts: You can add one or more delegated accounts only after selecting Other accounts.
      The format is Account ID/Agency Name. To specify multiple agencies, enter each one on a separate line.
    Resources
    • Entire bucket (including the objects in it): The policy applies to the bucket and the objects in it. You can configure bucket and object actions in this policy.
    • Current bucket: The policy applies to the current bucket. You can configure bucket actions in this policy.
    • Specified objects: The policy applies to specified objects in the bucket. You can configure object actions in this policy.
      • Multiple resource paths can be specified.
      • A resource path should be configured in the Folder name/Object name format, for example, testdir/a.txt. To specify the testdir folder and all objects in it, enter testdir/*.
      • You can specify a specific object, an object set, or a directory. * indicates all objects in the bucket.
        To specify a specific object, enter the object name.
        To specify a set of objects, enter Object name prefix*, *Object name suffix, or *. For example, testdir/* indicates objects in the testdir folder, and testprefix* indicates objects whose prefix is testprefix.
    Actions
    • Actions: Choose Customize.
    • Select Actions: See Bucket Policy Parameters.
      1. If you select Entire bucket (including the objects in it) for Resources, common actions, bucket actions, and object actions will be available for you to choose from.
      2. If you select Current bucket for Resources, common actions and bucket actions will be available for you to choose from.
      3. If you select Specified objects for Resources, common actions and object actions will be available for you to choose from.
      4. If you select both Current bucket and Specified objects for Resources, common actions, bucket actions, and object actions will be available for you to choose from.
    Conditions (Optional)
    Advanced Settings > Exclude (Optional)
    • Specified principals
      • If this option is not selected, the bucket policy applies to the specified users.
      • If this option is selected, the bucket policy applies to users except the specified ones.
    • Specified resources
      • If this option is not selected, the bucket policy applies to the specified OBS resources.
      • If this option is selected, the bucket policy applies to OBS resources except the specified ones.
    • Specified actions
      • If this option is not selected, the bucket policy applies to the specified actions.
      • If this option is selected, the bucket policy applies to actions except the specified ones. Suppose that you select Allow for Effect and DeleteObject for Actions. If you select Specified actions for Exclude (Optional), all operations except object deletion are allowed.
      By default, Specified actions is selected for Exclude in the bucket read/write template only. The action exclusion setting in bucket policy templates cannot be modified.
  6. Click Create in the lower right corner.
