Updated on 2025-04-08 GMT+08:00
Getting the Average RGB Value of an Image
You can get the average RGB value of an image only by making an API call.
The returned average RGB value is a hexadecimal string in JSON.
This operation is represented by average-hue.
Example
Below gives an example of querying the average RGB value of the example.jpg image:
https://hw-image-demo.obs.ap-southeast-1.myhuaweicloud.com/example.jpg?x-image-process=image/average-hue
If information similar to the following is displayed, the average RGB value of the image is obtained:
{"RGB":"#28577D"}
Original example.jpg image:
Color corresponding to the average RGB value (#28577D):
