Updated on 2026-09-10 GMT+08:00
Changing Image Quality
You can edit code on OBS Console or make an API call to change image quality.
For details about how to use image styles, see Step 3: Creating an Image Style and Processing the Image.
Only JPG and WebP images support quality changes.
To save space, you can compress JPG images. Table 1 describes the parameters.
This operation is represented by quality.
Table 1 Image compression parameters
Value Description
Code Example
q
Relative quality of the image. The image is compressed to q% of the original. The value ranges from 1 to 100.
Formula for compression: Target quality = Original quality × q%
For example, if the original image quality is 100% and the relative quality is 80%, then the target image quality is 80%. If the original quality is 80% and the relative quality is 80%, then the target quality is 64%.
image/resize,w_100,h_100/quality,q_80
Q
Absolute quality of the image. The image is compressed into Q%. Q is irrelevant to and does not depend on the original image. The value ranges from 1 to 100.
Formulas for compression:
  • Original quality > Q%: target quality = Q%
  • Original quality = Q%: target quality = original quality = Q%
  • Original quality < Q%: target quality = original quality
For example, if the original image quality is 100% and the absolute quality is 80%, then the target image quality is 80%. If the original quality is 70% and the absolute quality is 80%, then the target quality is 70%.
  • q is valid only for JPG images.
  • If both q and Q are used, the output is based on Q.
Examples
