You need to create a DApp project by selecting a specified network and setting a whitelist.
   - You have registered with Huawei Cloud.
   - You have purchased a package.
   - Log in to the NES console.
   - Choose Shared > DApp Project Management and click Create DApp Project.
   - Configure parameters.
     Figure 1 Creating a DApp project
       Table 1 DApp parameters
          Parameter  |
          Description  |
          DApp Name  |
          Enter 1 to 10 letters and digits.  |
          Public Blockchain  |
          There are Ethereum, TRON, Polygon PoS, Arbitrum, and BNB Smart Chain.
          - Ethereum: an open-source, blockchain-based computing platform featuring smart contract functionality
          - TRON: a blockchain-based, decentralized operating system
          - Polygon PoS: an L2 solution or a side chain, with its PoS Chains interconnected and communicating with the Ethereum mainnet
          - Arbitrum: a layer 2 scaling solution for the Ethereum blockchain. It aims to enhance scalability and reduce network congestion and transaction fees while maintaining the compatibility and security of the Ethereum Virtual Machine (EVM).
          - BNB Smart Chain: an EVM-compatible blockchain. It contains consensus layers and hubs to multiple blockchains. As a leading blockchain, BNB Smart Chain serves as an essential infrastructure, offers low-cost transactions and fast processing, and prioritizes privacy.
          Mainnet & Testnet  |
          For Ethereum, there are Mainnet and Sepolia.
          - Mainnet: a PoS mainnet for real transactions
          - Sepolia: a PoS testnet with a small amount of data and fast node startup speed
         For TRON, there are Mainnet and Nile.
          - Mainnet: a DPoS mainnet for real transactions
          - Nile: a DPoS testnet with a small amount of data and fast node startup speed
         For Polygon PoS, there are Mainnet and Mumbai.
          - Mainnet: The PoS mechanism and compatibility with EVMs make mainnet the preferred choice for fast transactions and low costs.
          - Mumbai: a replica of mainnet. Mumbai allows you to develop, test, and deploy your DApps.
         For Arbitrum, there are One and Goerli.
          - One: an optimistic rollup chain that supports EVMs and lets you efficiently perform transactions at low costs
          - Goerli: a replica of mainnet. Goerli allows you to develop, test, and deploy your DApps
         For BNB Smart Chain, there are Mainnet and Chapel.
          - Mainnet: an EVM-compatible, PoSA mainnet, with shorter block time and lower fees.
          - Chapel: a replica of mainnet. Chapel allows you to develop, test, and deploy your DApps.
          Description  |
          Describe your project in 300 characters.  |
          Advanced Settings  |
          You can set whitelists to restrict access to your DApp.
         Click   and configure whitelist information as prompted.
          - Options of Access Control By:
Blockchain Address: Your DApp can only send query requests to the whitelisted addresses.
           User-Agent: Your DApp can only receive requests sent by the whitelisted user-agents.
           IP Address: Your DApp can only receive requests sent by the whitelisted IP addresses.
           JSON Web Token (JWT): A JWT is an Internet standard (RFC 7519) that defines a process for secure data exchange between two parties. Your DApp can only receive requests that include the whitelisted JWTs.
           HTTP Origin: Your DApp can only receive requests sent by the whitelisted domain names and URLs.
          - Content:
            - Blockchain Address: Enter an account or contract address. For example: 0xed10421561cc4ee07e3a9b32ce6829b7ac902490
            - User-Agent: Enter user-agent information. For example: mobileDapp
            - IP Address: Enter an IP address. For example: 123.123.123.123
            - JSON Web Token (JWT): Enter a public key. For example:
-----BEGIN PUBLIC KEY-----
             -----END PUBLIC KEY-----
            - HTTP Origin: Enter a URL. For example: https://www.huawei.com/en/
   - Click Create.
