MRS Cluster User Accounts
This section describes information about default users in MRS clusters.
Account List (MRS 3.x and Later Versions)
- User types
The MRS cluster provides the following three types of users. The system administrator needs to periodically change the passwords. It is not recommended to use the default passwords.
User Type
System users
- User created on FusionInsight Manager for O&M and service scenarios. There are two types of users:
- Human-machine user: used in scenarios such as FusionInsight Manager O&M and operations on a component client. When creating a user of this type, you need to set password and confirm password by referring to Creating an MRS Cluster User.
- Machine-machine user: used for system application development.
- User who runs OMS processes
Internal system users
Internal user to perform Kerberos authentication, process communications, save user group information, and associate user permissions. It is recommended that internal system users not be used in O&M scenarios. Operations can be performed as user admin or another user created by the system administrator based on service requirements.
Database users
- User who manages OMS database and accesses data
- User who runs service components (Hue, Hive, HetuEngine, Loader, Oozie, Ranger, JobGateway, and DBService) in the database.
- System user
- User root of the OS is required, the password of user root on all nodes must be the same.
- User ldap of the OS is required. Do not delete this account. Otherwise, the cluster may not work properly. The OS administrator is responsible for maintaining password management policies.
User Type
Username
Initial Password
Password Change Method
System administrator
admin
User-defined password
FusionInsight Manager administrator.
By default, user admin does not have management permission on other components. For example, when accessing the native UI of a component, the user cannot view complete component information due to insufficient management permissions on the component.
For details, see Changing or Resetting the Password for User admin of an MRS Cluster.
Node OS user
ommdba
Random password
User that creates the system database. This user is an OS user generated on the management node and does not require a unified password. This account cannot be used for remote login.
For details, see Changing the Passwords for OS Users of an MRS Cluster Node.
omm
Random password
Internal running user of the system. This user is an OS user generated on all nodes and does not require a unified password.
- Internal system user
User Type
Default User
Initial Password
Kerberos administrator
kadmin/admin
Admin@123
Used to add, delete, modify, and query user accounts on Kerberos.
For details, see Changing the Password for the Kerberos Administrator of an MRS Cluster.
OMS Kerberos administrator
kadmin/admin
Admin@123
Used to add, delete, modify, and query user accounts on OMS Kerberos.
For details, see Changing the Password of the OMS Kerberos Administrator.
LDAP administrator
cn=root,dc=hadoop,dc=com
- Versions earlier than MRS 3.1.2: LdapChangeMe@123
- MRS 3.1.2 or later: randomly generated by the system
Used to add, delete, modify, and query the user account information on LDAP.
- For versions earlier than MRS 3.1.2, see Changing the Password for a Regular LDAP User of an MRS Cluster.
- For MRS 3.1.2 or later, see Modifying the OMS Service Configuration.
OMS LDAP administrator
Used to add, delete, modify, and query the user account information on OMS LDAP.
LDAP user
cn=pg_search_dn,ou=Users,dc=hadoop,dc=com
Randomly generated by the system
Used to query information about users and user groups on LDAP.
OMS LDAP user
Used to query information about users and user groups on OMS LDAP.
LDAP administrator account
cn=krbkdc,ou=Users,dc=hadoop,dc=com
Used to query Kerberos component authentication account information.
- For versions earlier than MRS 3.1.2, see Changing the LDAP Administrator Password for an MRS Cluster.
cn=krbadmin,ou=Users,dc=hadoop,dc=com
Used to add, delete, modify, and query Kerberos component authentication account information.
Component running user
hdfs
Hdfs@123
This user is the HDFS system administrator and has the following permissions:
- File system operation permissions:
- Views, modifies, and creates files.
- Views and creates directories.
- Views and modifies the groups where files belong.
- Views and sets disk quotas for users.
- HDFS management operation permissions:
- Views the web UI status.
- Views and sets the active and standby HDFS status.
- Enters and exits the HDFS in security mode.
- Checks the HDFS file system.
- Logs in to the FTP service page.
For details, see Changing the Passwords for MRS Cluster Component Running Users.
hbase
Hbase@123
This user is the HBase and HBase1 to HBase4 system administrator and has the following permissions:
- Cluster management permission: Performs Enable and Disable operations on tables to trigger MajorCompact and ACL operations.
- Grants and revokes permissions, and shuts down the cluster.
- Table management permission: Creates, modifies, and deletes tables.
- Data management permission: Reads data in tables, column families, and columns.
- Logs in to the HMaster web UI.
cdl
CDCUser123!
System administrator of the CDL
Currently, CDL does not involve user permissions.
iotdb
Iotdb@123
This user is the IoTDB system administrator and has the following user permissions:
- IoTDB administrator permissions:
- Creates or deletes a storage group.
- Uses TTL.
- IoTDB data operation permissions:
- Creates, modifies, and deletes a time sequence.
- Writes, reads, and deletes data in a time sequence.
- Views user or role permission information.
- Grants or revokes permissions for a user or role.
In a normal cluster, the IoTDB service retains the features of open-source versions. The default username is root, and the default password is root (for MRS 3.3.0 or later, the default password is Iotdb@123). This user is an administrator and has all permissions, which cannot be assigned, revoked, or deleted.
mapred
Mapred@123
This user is the MapReduce system administrator and has the following permissions:
- Submits, stops, and views the MapReduce tasks.
- Modifies the Yarn configuration parameters.
- Logs in to the Yarn web UI.
zookeeper
ZooKeeper@123
This user is the ZooKeeper system administrator and has the following permissions:
- Adds, deletes, modifies, and queries all nodes in ZooKeeper.
- Modifies and queries quotas of all nodes in ZooKeeper.
rangeradmin
Rangeradmin@123
This user has the Ranger system management permissions and user permissions:
- Ranger web UI management permission
- Management permission of each component that uses Ranger authentication
rangerauditor
Rangerauditor@123
Default audit user of the Ranger system.
hive
Hive@123
This user is the Hive system administrator and has the following permissions:
- Hive administrator permissions:
- Creates, deletes, and modifies a database.
- Creates, queries, modifies, and deletes a table.
- Queries, inserts, and uploads data.
- HDFS file operation permissions:
- Submits and stops the MapReduce tasks.
- Ranger policy management permission
kafka
Kafka@123
This user is the Kafka system administrator and has the following permissions:
- Creates, deletes, produces, and consumes the topic; modifies the topic configuration.
- Controls the cluster metadata, modifies the configuration, migrates the replica, elects the leader, and manages ACL.
- Submits, queries, and deletes the consumer group offset.
- Queries the delegation token.
- Queries and submits the transaction.
storm
Admin@123
Storm system administrator
User permission: Submits Storm tasks.
rangerusersync
Synchronizes users and internal users of user groups.
rangertagsync
Internal user for synchronizing tags.
rangerobs/hadoop.<System domain name>
System administrator used by Guardian to access Ranger
jobserver
JobGateway system administrator, who has the following permissions:
- Manager administrator permission
HTTP/_HOST
Internal user of the JobGateway service, which is used for Kerberos authentication of the HTTP service
oms/manager
Controller and NodeAgent authentication user. The user has the permission on the supergroup group.
backup/manager
User for running backup and restoration tasks. The user has the permission on the supergroup, wheel, and ficommon groups. After cross-system mutual trust is configured, the user has the permission to access data in the HDFS, HBase, Hive, and ZooKeeper systems.
hdfs/hadoop.<System domain name>
This user is used to start the HDFS and has the following permissions:
hetuserver/hadoop.<System domain name>
This user is used to start HetuEngine and has the following permissions:
- Accesses KrbServer and HDFS files in the cluster from HetuEngine.
- Used for communication between HetuEngine internal nodes.
mapred/hadoop.<System domain name>
This user is used to start the MapReduce and has the following permissions:
mr_zk/hadoop.<System domain name>
Used for MapReduce to access ZooKeeper.
hbase/hadoop.<System domain name>
User for the authentication between internal components during the HBase system startup.
hbase/zkclient.<System domain name>
User for HBase to perform ZooKeeper authentication in a security mode cluster.
thrift/hadoop.<System domain name>
ThriftServer system startup user.
thrift/<hostname>
User for the ThriftServer system to access HBase. This user has the read, write, execution, creation, and administration permission on all NameSpaces and tables of HBase. <hostname> indicates the name of the host where the ThriftServer node is installed in the cluster.
hive/hadoop.<System domain name>
User for the authentication between internal components during the Hive system startup. The user permissions are as follows:
loader/hadoop.<System domain name>
User for Loader system startup and Kerberos authentication
HTTP/<hostname>
Used to connect to the HTTP interface of each component. <hostname> indicates the host name of a node in the cluster.
hue
User for Hue system startup, Kerberos authentication, and HDFS and Hive access
flume
User for Flume system startup and HDFS and Kafka access. The user has read and write permission of the HDFS directory /flume.
flume_server
spark2x/hadoop.<System domain name>
This user is the Spark2x system administrator and has the following user permissions:
1. Starts the Spark2x service.
2. Submits Spark2x tasks.
spark_zk/hadoop.<System domain name>
Used for Spark2x to access ZooKeeper.
zookeeper/hadoop.<System domain name>
ZooKeeper system startup user.
zkcli/hadoop.<System domain name>
ZooKeeper server login user.
oozie
User for Oozie system startup and Kerberos authentication.
kafka/hadoop.<System domain name>
Used for security authentication of Kafka.
storm/hadoop.<System domain name>
Storm system startup user.
storm_zk/hadoop.<System domain name>
Used for the Worker process to access ZooKeeper.
flink/hadoop.<System domain name>
Internal user of the Flink service.
check_ker_M
User who performs a system internal test about whether the Kerberos service is normal.
cdl/hadoop.<System domain name>
Internal user of the CDL service.
clickhouse/hadoop.<System domain name>
Used for security authentication of ClickHouse. This user is an internal user and can be used only in the cluster.
default
None
ClickHouse internal user, which is an administrator user that can be used only in non-security mode.
rangeradmin/hadoop.<System domain name>
Ranger system startup user, which is used for authentication between internal components.
tez
User for TezUI system startup, Kerberos authentication, and access to Yarn
K/M
Kerberos internal functional user. It cannot be deleted, and its password cannot be changed. This internal account can only be used on nodes where Kerberos service is installed.
None
kadmin/changepw
kadmin/history
krbtgt<System domain name>
LDAP user
admin
None
The primary group is compcommon, which does not have the group permission but has the permission of the Manager_administrator role.
The LDAP user cannot log in to the system, and the password cannot be changed.
backup
The primary group is compcommon.
backup/manager
oms
oms/manager
clientregister
zookeeper
The primary group is hadoop.
zkcli
flume
flume_server
hdfs
mapred
mr_zk
hue
The primary group is supergroup.
hive
The primary group is hive.
hbase
thrift
oozie
loader
spark2x
spark_zk
kafka
The primary group is kafkaadmin.
storm
The primary group is stormadmin.
storm_zk
The primary group is storm.
kms/hadoop
The primary group is kmsadmin.
knox
executor
rangeradmin
rangerusersync
rangertagsync
rangerauditor
jobserver
Log in to FusionInsight Manager, choose System > Permission > Domain and Mutual Trust, and check the value of Local Domain. In the preceding table, all letters in the system domain name contained in the username of the system internal user are lowercase letters.
For example, if Local Domain is set to 9427068F-6EFA-4833-B43E-60CB641E5B6C.COM, the username of default HDFS startup user is hdfs/hadoop.9427068f-6efa-4833-b43e-60cb641e5b6c.com.
- Database user The system database users include OMS database users and DBService database users.
Database Type
Default User
Initial Password
OMS database
ommdba
- Versions earlier than MRS 3.2.0: dbChangeMe@123456
- MRS 3.2.0 or later: random password
OMS database administrator who performs maintenance operations, such as creating, starting, and stopping.
For details, see Changing the Password for the OMS Database Administrator.
omm
- Versions earlier than MRS 3.2.0: ChangeMe@123456
User for accessing OMS database data
For details, see Changing the Password for an OMS Database Access User.
DBService database
omm
- Versions earlier than MRS 3.2.0: dbserverAdmin@123
- MRS 3.2.0 or later: random password. If you need to obtain the password, contact technical support.
Administrator of the GaussDB database in the DBService component
For details, see Resetting the Password for User omm in DBService.
compdbuser
Random password
(Available in MRS 3.1.2 or later) Administrator of the GaussDB database in the DBService component. It is used in service O&M scenarios. You need to reset the password upon your first login.
For details, see Changing the Password for User compdbuser of the DBService Database.
hetu
Random password
User for HetuEngine to connect to the DBService database hetumeta.
This user exists only in MRS 3.1.2 or later.
- For versions earlier than MRS 3.1.2, see Changing the Passwords for Database Users of MRS Cluster Components.
- For MRS 3.1.2 or later, see Resetting the MRS Component Database User Password.
hive
- Versions earlier than MRS 3.1.2: HiveUser@
- MRS 3.1.2 or later: random password
User for Hive to connect to the DBService database hivemeta.
hue
- Versions earlier than MRS 3.1.2: HueUser@123
User for Hue to connect to the DBService database hue.
sqoop
- Versions earlier than MRS 3.1.2: SqoopUser@
User for Loader to connect to the DBService database sqoop.
oozie
- Versions earlier than MRS 3.1.2: OozieUser@
User for Oozie to connect to the DBService database oozie.
rangeradmin
- Versions earlier than MRS 3.1.2: Admin12!
User for Ranger to connect to the DBService database.
kafkaui
Random password
User for Kafka UI to connect to the DBService database.
flink
Random password
User for Flink to connect to the DBService database flinkmeta.
cdl
Random password
User for CDL to connect to the DBService database cdl.
This user exists only in MRS 3.2.0 or later.
jobgateway
Random password
User for JobGateway to connect to the DBService database jobmeta.
This user can be used in MRS 3.3.0 and later versions only.
Account List (MRS 2.x and Earlier Versions)
- User type
The MRS cluster provides the following three types of users. Periodically change the passwords and do not use the default passwords.
User Type
System users
- User created on Manager for MRS cluster O&M and service scenarios. There are two types of system users:
- Human-machine user: used for Manager O&M scenarios and component client operation scenarios.
- Machine-machine user: used for MRS cluster application development scenarios.
Database users
- User who runs the database of service components (Hive, Loader, and DBService)
- System user
User ldap of the OS is required in the MRS cluster. Do not delete this account. Otherwise, the cluster may not work properly. Operation users are responsible for maintaining password management policies.
When you change the passwords of users ommdba and omm for the first time, you must reset them. Change the passwords periodically after retrieving them.
User Type
Username
Initial Password
System administrator of the MRS cluster
admin
Specified by the user during the cluster creation.
MRS Manager
The user has the following permissions:
- Common HDFS and ZooKeeper user permissions.
- Permissions to submit and query MapReduce and YARN tasks, manage YARN queues, and access the YARN web UI.
- Permissions to submit, query, activate, deactivate, reassign, delete topologies, and operate all topologies of the Storm service.
- Permissions to create, delete, authorize, reassign, consume, write, and query topics of the Kafka service.
MRS cluster node OS user
omm
Internal running user of the MRS cluster system. This user is an OS user generated on all nodes and does not require a unified password.
root
The password is set by the user.
User for logging in to the node in the MRS cluster. This user is an OS user generated on all nodes.
- Do not delete the following internal system users. Deleting them may cause the cluster or components to malfunction.
- These users are available only in clusters with Kerberos authentication enabled.
User Type
Default User
Initial Password
hdfs
Hdfs@123
hbase
Hbase@123
This user is the HBase system administrator and has the following permissions:
- Cluster management permission: Enable and Disable operations on tables to trigger MajorCompact and ACL operations.
- Accesses the HBase web UI.
mapred
Mapred@123
- Accesses the Yarn and MapReduce web UI.
spark
Spark@123
This user is the Spark system administrator and has the following permissions:
- Accesses the Spark web UI.
- Submits Spark tasks.
- User group information
Default User Group
supergroup
Primary group of user admin, which has no additional permissions in the cluster with Kerberos authentication disabled.
check_sec_ldap
Used to test whether the active LDAP works properly. This user group is generated randomly in a test and automatically deleted after the test is complete. This is an internal system user group used only between components.
Manager_tenant
Tenant system user group, which is an internal system user group used only between components. It is used only in clusters with Kerberos authentication enabled.
System_administrator
MRS cluster system administrator group, which is an internal system user group used only between components. It is used only in clusters with Kerberos authentication enabled.
Manager_viewer
MRS Manager system viewer group, which is an internal system user group used only between components. It is used only in clusters with Kerberos authentication enabled.
Manager_operator
MRS Manager system operator group, which is an internal system user group used only between components. It is used only in clusters with Kerberos authentication enabled.
Manager_auditor
MRS Manager system auditor group, which is an internal system user group used only between components. It is used only in clusters with Kerberos authentication enabled.
MRS Manager system administrator group, which is an internal system user group used only between components. It is used only in clusters with Kerberos authentication enabled.
compcommon
MRS cluster internal group, used to access public resources in the cluster. All system users and system running users are added to this user group by default.
default_1000
User group created for tenants. This is an internal system user group used only between components.
launcher-job
MRS internal group, which is used to submit jobs using V2 APIs.
hadoop
Users added to this user group have the permission to submit tasks to all YARN queues. This type of user is available only in clusters with Kerberos authentication enabled.
hbase
Common user group. Users added to this user group will not have any additional permission. This type of user is available only in clusters with Kerberos authentication enabled.
hive
Users added to this user group can use Hive. This type of user is available only in clusters with Kerberos authentication enabled.
spark
kafka
Kafka common user group. Users added to this group need to be granted with read and write permission by users in the kafkaadmin group before accessing the desired topics. This type of user is available only in clusters with Kerberos authentication enabled.
kafkasuperuser
Users added to this group have permissions to read data from and write data to all topics. This type of user is available only in clusters with Kerberos authentication enabled.
kafkaadmin
Kafka administrator group. Users added to this group have the permissions to create, delete, authorize, as well as read from and write data to all topics. This type of user is available only in clusters with Kerberos authentication enabled.
storm
Storm common user group. Users added to this group have the permissions to submit topologies and manage their own topologies. This type of user is available only in clusters with Kerberos authentication enabled.
stormadmin
Storm administrator user group. Users added to this group have the permissions to submit topologies and manage their own topologies. This type of user is available only in clusters with Kerberos authentication enabled.
opentsdb
presto
flume
launcher-job
MRS internal group, which is used to submit jobs using V2 APIs. This type of user is available only in clusters with Kerberos authentication enabled.
OS User Group
wheel
Primary group of MRS internal running user omm.
ficommon
MRS cluster common group that corresponds to compcommon for accessing public resource files stored in the OS of the cluster.
- Database user
MRS cluster system database users include OMS database users and DBService database users.
Do not delete database users. Deleting them may cause the cluster or components to malfunction.
User Type
Default User
Initial Password
OMS database
ommdba
dbChangeMe@123456
omm
ChangeMe@123456
DBService database
omm
dbserverAdmin@123
hive
HiveUser@
User for Hive to connect to the DBService database.
hue
HueUser@123
User for Hue to connect to the DBService database.
ranger
RangerUser@
User for Ranger to connect to the DBService database. This type of user is available only in clusters with Kerberos authentication enabled.
sqoop
SqoopUser@
User for Loader to connect to the DBService database.
