Updated on 2026-09-24 GMT+08:00
Backing Up DBService Data
To ensure DBService service data security routinely or before a major operation on DBService (such as upgrade or migration), you need to back up DBService data. The backup data can be used to recover the system if an exception occurs or the operation has not achieved the expected result, minimizing the adverse impacts on services.
DBService metadata backup tasks can be created on FusionInsight Manager. The system supports both automatic and manual backup modes.
MRS clusters support multiple data path types for backing up DBService metadata.
  • LocalDir: indicates that backup files are stored on the local disk of the active management node, with the standby management node automatically synchronizing the backup files.
    The default storage directory is Data storage path/LocalBackup/, for example, /srv/BigData/LocalBackup.
  • LocalHDFS: indicates that backup files are stored in the HDFS directory of the current cluster.
  • RemoteHDFS: indicates that backup files are stored in the HDFS directory of the standby cluster.
  • NFS: indicates that backup files are stored in NAS using the NFS protocol.
  • CIFS: indicates that backup files are stored in NAS using the CIFS protocol.
  • SFTP: indicates that backup files are stored in the server using the SFTP protocol.
  • OBS: indicates that backup files are stored in OBS.
Notes and Constraints
MRS 3.1.0 and later versions support the backup of DBService metadata to OBS.
  • To back up data to a remote HDFS, the following conditions must be met:
    • A standby cluster for backing up data has been created. Its authentication mode must be the same as that of the active cluster.
    • If the active cluster is deployed in security mode and the active and standby clusters are not managed by the same FusionInsight Manager, mutual trust has been configured. For details, see Configuring Mutual Trust Between MRS Clusters. If the active cluster is deployed in normal mode, mutual trust is not required.
    • Cross-cluster replication has been configured for the active and standby clusters. For details, see Enabling MRS Inter-Cluster Replication.
    • Time is consistent between the active and standby clusters, with the NTP services on both clusters configured to use the same time source.
  • The backup type, period, policy, and other specifications have been planned based on the service requirements and you have checked whether Data storage path/LocalBackup/ has sufficient space on the active and standby management nodes.
  • If you want to back up data to NAS, you have deployed the NAS server in advance.
  • If you want to back up data to OBS, you have connected the current cluster to OBS and have the permission to access OBS.
  1. Log in to MRS Manager.
    For details about how to log in to MRS Manager, see Accessing MRS Manager.
  2. Choose O&M > Backup and Restoration > Backup Management.
  3. Click Create.
  4. Set Name to the name of the backup task.
  5. Select the cluster to be operated from Backup Object.
  6. Set Mode to the type of the backup task.
    Periodic indicates that the backup task is executed by the system periodically. Manual indicates that the backup task is executed manually.
    Table 1 Periodic backup parameters
    Example Value
    Started
    2024/11/22 10:29:11
    Time when the task should start for the first time.
    Period
    1 day
    Task execution interval. Supported values are Hours and Days.
    Backup Policy
    Full backup every time
    • Full backup at the first time and incremental backup subsequently
    • Full backup every time
    • Full backup once every n times
    Incremental backup is not supported for Manager data and component metadata. Only Full backup every time is supported.
    If Path Type is set to NFS or CIFS, incremental backup cannot be used. When incremental backup is used for NFS or CIFS backup, the latest full backup data is updated each time the incremental backup is performed. Therefore, no new recovery point is generated.
  7. In Configuration, select DBService.
  8. Select a backup directory type for Path Type of DBService.
    Table 2 Path of backup data
    Path Type
    LocalDir
    Maximum Number of Backup Copies
    Number of backup files that can be retained in the backup directory.
    LocalHDFS
    Target Path
    HDFS directory for storing the backup files.
    • The path cannot be configured as an HDFS hidden directory, such as a snapshot or recycle bin directory.
    • The path cannot be configured as a default system directory, such as /hbase or /user/hbase/backup.
    Target NameService Name
    NameService name of the backup directory. The default value is hacluster.
    RemoteHDFS
    Destination NameService Name
    Name of the NameService in the standby cluster.
    • You can set it to the NameService name (haclusterX, haclusterX1, haclusterX2, haclusterX3, or haclusterX4) of the built-in remote cluster.
    • You can also set it to the NameService name of a configured remote cluster.
    IP Mode
    IP version of the target IP address. The system automatically determines the IP version, such as IPv4 or IPv6, based on the cluster network type.
    Target NameNode IP Address
    Service plane IP address of the active or standby NameNode in the standby cluster.
    Target Path
    HDFS directory in the standby cluster for storing backup data.
    Queue Name
    Name of the YARN queue used for backup task execution.
    The name must be identical to that of a queue currently running properly in the cluster.
    NFS
    IP Mode
    Server IP Address
    IP address of the NAS server.
    Server Shared Path
    Shared directory configured on the NAS server by the user.
    The shared directory of the server cannot be set to the root directory. The user group and owner group of the shared directory must be configured as nobody:nobody.
    CIFS
    IP Mode
    Server IP Address
    Port
    Port number used by the CIFS protocol to connect to the NAS server.
    The default value is 445.
    Username
    Username configured during CIFS protocol setup.
    Password
    Password configured during CIFS protocol setup.
    Server Shared Path
    SFTP
    IP Mode
    Server IP Address
    IP address of the server where the backup data is stored.
    Port
    Port number used by the SFTP protocol to connect to the backup server.
    The default value is 22.
    Username
    Username used to connect to the server over SFTP.
    Password
    Password used to connect to the server over SFTP.
    Server Shared Path
    Backup path on the SFTP server.
    OBS
    Target Path
    OBS directory for storing backup data.
  9. Click OK.
  10. In the Operation column of the created task in the backup task list, click More and select Back Up Now to execute the backup task.
    After the backup task is executed, the system automatically creates a subdirectory for each backup task in the backup directory. The format of the subdirectory name is Backup task name_Task creation time, and the subdirectory is used to save data source backup files. The format of the backup file name is Version_Data source_Task execution time.tar.gz.
Helpful Links
Backup DBService metadata may be restored if data is accidentally modified, deleted, or requires retrieval; if major DBService operations (such as upgrades or significant data adjustments) cause exceptions in system data or fail to achieve the expected result; if all modules fail and become unavailable; or if data needs to be migrated to a new cluster. For detailed operations, refer to Restoring DBService Metadata.
