Updated on 2025-08-11 GMT+08:00
Searching for MRS Cluster Logs Online
On the MRS Manager page, administrators can easily search for and view all component log files by node or component role to identify faults through keyword analysis.
Notes and Constraints
This section applies only to MRS 3.x or later.
Video Tutorial
This video shows how to search for and download component logs on the MRS Manager.
The UI may vary depending on the version. This tutorial is for reference only.
Searching for Logs Online
  1. Log in to FusionInsight Manager of the MRS cluster.
    For details about how to log in to FusionInsight Manager, see Accessing MRS Manager.
  2. Choose O&M > Log > Online Search.
    Figure 1 Online Search
  3. Set parameters based on Table 1. You can select a log search duration or click to specify Start Time and End Time.
    Table 1 Log search parameters
    Search Content
    Keywords or regular expression to be searched for
    Service
    Service or module for which you want to query logs
    File
    Log files to be searched for when only one role is selected
    Lowest Log Level
    Lowest level of logs to be queried. After you select a level, the logs of this level and higher levels are displayed.
    The levels in ascending order are as follows:
    TRACE < DEBUG < INFO < WARN < ERROR < FATAL
    Host Scope
    • Click to select required hosts. If no host is specified, all hosts are selected by default.
    • Enter the host name of the node for which you want to query logs or the IP address of the management plane.
    • Use commas (,) to separate IP addresses, for example, 192.168.10.10,192.168.10.11.
    • Use hyphens (-) to indicate an IP address segment if the IP addresses are consecutive, for example, 192.168.10.[10-20].
    • Use hyphens (-) to indicate an IP address segment if the IP addresses are consecutive, and use commas (,) to separate IP address segments, for example, 192.168.10.[10-20,30-40].
    • A maximum of 10 IP address expressions can be entered at a time. A maximum of 2,000 hosts can be matched for all entered expressions at a time.
    Advanced Configurations
    • Max Quantity: maximum number of logs that can be displayed at a time. If the number of queried logs exceeds the value of this parameter, the earliest logs will be ignored. If this parameter is not set, the maximum number of logs that can be displayed at a time is not limited.
    • Timeout Duration: log query timeout duration. This parameter is used to limit the maximum log query time on each node. When the query times out, the query is stopped and the logs that have been searched for are still displayed.
  4. Click Search. Table 2 describes the fields in search results.
    Table 2 Parameters in search results
    Time
    Time when a line of log is generated
    Host Name
    Host name of the node where the log file recording the line of log is located
    Location
    Path of the log file recording the line of log
    Click the location information to go to the online log browsing page. By default, 100 lines of logs before and 100 lines after the line of log are displayed. You can click Load More on the top or bottom of the page to view more logs. Click Download to download the log file to the local PC.
    Line No.
    Line number of a line of log in the log file
    Level
    Level of the line of log
    Log
    Log content
    You can click Stop to forcibly stop the search. You can view the search results in the list.
  5. Click Filter to filter the logs to display on the page. Table 3 lists the fields that you can use to filter logs. After you configure these parameters, click Filter to search for logs meeting the search criteria. You can click Reset to clear the information that you have filled in.
    Table 3 Parameters for filtering logs
    Keywords
    Keywords of the logs to be searched for
    Host Name
    Name of the host to be searched for
    Location
    Path of the log file to be searched for
    Started
    Start time for logs to be searched for
    Completed
    End time for logs to be searched for
Helpful Links
