Help Center/ Enterprise Self-Service Management/ User Guide/ Personal Center/ Configuring Message Notifications/ Managing Agencies
Updated on 2025-11-05 GMT+08:00
Managing Agencies
You can update or modify an SMN agency.
- You have purchased the professional edition of ESM.
- You have logged in to ESM as an administrator.
- Log in to the IAM console.
- In the navigation pane, choose Agencies. Figure 1 Agency
- In the agency list, locate the row that contains the esm_agency agency and click its name.
- Click the Permissions tab, locate SMN FullAccess, and click Delete in the Operation column.
- Click OK.
- Log in to ESM. In the upper right corner of the page, click the username and select Notification.
- On the displayed authorization page, read the authorization information. For details, see Authorization.
- After the authorization is successful, check whether the minimum and necessary permissions required by SMN are displayed.
Parent topic: Configuring Message Notifications
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
