Configuration Management (Applicable to Engine 2.x)
ServiceComb engines define a configuration mechanism that is irrelevant to development frameworks. A configuration item consists of a key, label, and value. The label is used to identify whether a configuration item belongs to global configuration or microservice configuration. The label can also indicate the value type.
Configuration items are stored in plaintext. Do not include sensitive data.
Operation |
Description |
Associates the new configuration with an application, and adds the application name and environment label. |
Associates the new configuration with a microservice, and adds the microservice name, application name, and environment. |
If application-level and microservice-level configurations cannot meet service requirements, you can customize configuration files. |
Imports the local configuration file. |
Exports the selected configuration file to the local host. |
Compares differences between historical versions. |
Rolls back to the selected historical version. |
Displays configurations of different historical versions. |
Edits a configuration item. |
Disables a configuration item. |
Deletes a configuration item. |
When the configuration item quota specified by the engine specifications is about to be used up, the engine allows new configuration items that exceed the remaining quota to be created to ensure capacity availability. Expand the capacity of the engine as soon as possible to prevent configuration creation failures.
Creating an Application-Level Configuration
- Log in to CSE.
- Choose Exclusive ServiceComb Engines.
- Click the target engine.
- Choose Configuration Management.
- In the displayed Security Authentication dialog box, enter the account name and password, and click OK.
- If you connect to the ServiceComb engine for the first time, enter the account name root and the password entered when Creating a ServiceComb Engine.
- For details about how to create an account, see Adding an Account.
- Click Create Configuration Item and set parameters by referring to the following table. Parameters marked with an asterisk (*) are mandatory.
*Configuration Item
Enter a configuration item.
The configuration item is the global ID of the configuration. In the coding phase, the configuration item is used to index and operate the configuration. You are advised to use the Java package naming rule (for example, cse.service.registry.address) to ensure the readability and uniqueness of the configuration.
Configuration items starting with servicecomb.matchGroup. cannot be created during application-level configuration creation. Such configuration items conflict with the configuration generated during service scenario governance creation, so the service scenario cannot be displayed.
Configuration Range
Select Application-level.
*Application
- Select or enter an application name.
- Select an environment.
Configuration Format
Select a configuration format. Common configuration formats such as TEXT, YAML, JSON, Properties, INI and XML can be edited online. The default value is TEXT.
*Configuration Content
Enter the configuration content.
Enable Configuration
Determine whether to enable the configuration item.
- Enable now: The configuration item takes effect immediately once created.
- Not Enabled: The configuration item does not take effect.
- Click Create Now to enable the configuration item.
Creating a Microservice-Level Configuration
- Log in to CSE.
*Configuration Item
Configuration Range
Select Microservice-level.
*Microservice
- Select or enter a microservice name.
Creating a Customized Configuration Item
- Log in to CSE.
*Configuration Item
Configuration Range
Select Customize.
*Labels
If application-level and microservice-level configurations cannot meet service requirements, you can use labels to customize configurations.
Importing Configurations
- Log in to CSE.
- Click Import in the upper right corner to Import files in different formats as required, and set parameters by referring to the following table.
Table 1 V2.0 file Parameter
File Format
Select a format of the file to be imported. The default format is V2.0.
Import to Specific Environment
- Disabled: The imported configuration does not change the environment label.
- Enabled: Importing the configuration to a specific environment will change the environment label. Select an environment from the drop-down list.
Same Configuration
- Terminate: If a configuration is the same as that in the system, the import terminates.
- Skip: During import, if a configuration is the same as that in the system, the configuration is skipped and other configurations are imported.
- Overwrite: During import, if a configuration is the same as that in the system, the value of the configuration will be replaced.
Configuration File
Click Import and select the target file.
The file size cannot exceed 2 MB.
Table 2 V1.0 file Parameter
File Format
Select V1.0.
*Import to Specific Environment
Select a microservice environment.
Microservice
Select the microservice to which the configuration is imported from the drop-down list.
Microservice Version
Select a version of the microservice to which the configuration is imported from the drop-down list.
*Configuration File
- Click Close.
Exporting Configurations
- Log in to CSE.
- Select the configuration items to be exported and click Export.
- Click Export above the configuration items. In the displayed dialog box, click Export.
- Click Export in the upper right corner. In the displayed dialog box, select the file format (V2.0 by default) and click OK.
If the format of the exported configuration file is V1.0, you need to select the microservice environment, microservice name, and microservice version from the drop-down list.
Comparing Configuration Versions
- Log in to CSE.
- Click the configuration item to be compared.
- Click View Historical Version.
- In Historical Versions on the left, select the historical version to be viewed.
In the Configuration file on the right, you can view the differences between the current and historical versions.
A maximum of 100 historical versions can be displayed.
Rolling Back a Version
- Log in to CSE.
- Click the target configuration item.
- In Historical Versions on the left, select the target historical version.
- In Configuration file on the right, click Roll Back to the Selected Version.
Viewing Historical Versions
- Log in to CSE.
- Click View Historical Version in the Operation column of a configuration item. On the Historical Versions page that is displayed, you can view the historical versions of the configuration item. On this page, you can compare the configuration version with the rollback version.
Editing a Configuration Item
- Log in to CSE.
- Click Edit in the Operation column of the target configuration item. You can also click the target configuration item and then click Edit on the displayed configuration details page.
- Enter the configuration information in the Configuration Content text box and click Save.
Disabling a Configuration Item
- Log in to CSE.
- In the Operation column of the target configuration item, click More > Disable.
- Click OK.
Deleting a Configuration Item
- Log in to CSE.
- Click Delete in the Operation column of the target configuration item. You can also click the target configuration item and then click Delete on the displayed configuration details page.
- Click OK.
