Deleting a Backup
You can delete unwanted backups to reduce space usage and costs.
Context
CSBS supports manual deletion of backups and automatic deletion of expired backups. The latter deletion method is implemented using the backup retention rule in the backup policy. For details, see Creating a Backup Policy.
- At least one backup exists in CSBS.
- The backups are in the Available or Error state.
- Log in to the CSBS management console.
- Under Storage > Cloud Server Backup Service.
- Click the Backups tab. Locate the ECS backup. For details, see Viewing a Backup.
- In the row of the backup, click More > Delete. See Figure 1. Alternatively, select the backups you want to delete and click Delete in the upper left corner to delete them in a batch.
- Click Yes.
