- What's New
- Getting Started
- User Guide
Best Practices
- Using a Custom Script to Implement Consistent Backup for MySQL
- Using a Custom Script to Implement Consistent Backup for SAP HANA
- Using a Custom Script to Implement Consistent Backup for Other Linux Applications
- Troubleshooting a Custom Script Error
- Verifying the Application-Consistent Backup Result (Linux)
- Verifying the Application-Consistent Backup Result (Windows)
- Protecting SQL Server in Failover Cluster Mode
- Protecting SQL Server in Always on Availability Groups Mode
- Change History
- API Reference
About Concepts
- What Is CSBS?
- What Are Full Backup and Incremental Backup?
- What Is Consistent Backup?
- What Are the Differences Between CSBS and VBS?
- What Is a Backup Policy?
- What Are the Differences Between Backup and Disaster Recovery?
- What Are the Differences Between Backup and Snapshot?
- Why Is the Disk Space Usage Displayed in the File System Different from the Backup Size?
About Pricing
- How Is CSBS Billed?
- How Do Yearly/Monthly Resource Packages Function When I Have Bought More Than One?
- Are CSBS and VBS Resource Packages Interoperable Between CSBS and VBS?
- Why Am I Charged in Pay-per-use Mode Although I Have Purchased Resource Package?
- What Exactly Are the Function Package and the Storage Package?
- Will the CSBS Backups Displayed on the VBS Page Be Charged Repeatedly?
- How Do I Query CSBS Pay-Per-Use Billing Details?
- Why Is the Fee Deducted After a Backup Is Deleted?
- How Do I Disable CSBS?
- How Do I Stop CSBS from Charging?
About Backup
- Does CSBS Support Backing Up All EVS Disks on an ECS?
- Do I Need to Stop the ECS Before Backing It Up?
- Can an ECS with Application Systems Be Backed Up?
- What Are the Minimum Backup Frequency and Maximum Number of Retained Backups Supported by CSBS?
- How Can I Distinguish Automatic Backups From Manual Backups?
- How Can I Configure a Backup Policy?
- Can I Choose to Back Up Only Some Partitions of a Disk?
- Does CSBS Support Cross-Region Backup for ECSs?
- Which Types of Databases Can Be Backed Up Using Database Server Backup?
- How Do I Select Among Database Server Backup, Cloud Server Backup, and Disk Backup?
- How Do I Migrate ECS Data Across Regions Using CSBS?
- Which Time Zone Is the Automatic Backup Time Based On?
- What Can I Do If a Backup Cannot Be Deleted?
- About Restoration
- Others
About Concepts
- Troubleshooting
- Videos
- Glossary
More Documents
User Guide (Paris and Amsterdam Regions)
- Getting Started
- Management Operations
- About Concepts
About Backup
- About Restoration
- Others
- Troubleshooting Cases
- Change History
- API Reference (Paris and Amsterdam Regions)
On this page
Show all
Help Center/
Cloud Server Backup Service/
User Guide/
Backup Policies/
Disassociating ECSs from a Backup Policy
When an ECS associated with a backup policy no longer needs to be backed up, you can disassociate it from the backup policy.
- You have created at least one backup policy.
- The backup policy is associated with at least one ECS.
- Log in to the CSBS management console.
- Under Storage > Cloud Server Backup Service.
- Click the Policies tab.
- In the row of the backup policy from which you want to disassociate the ECS, click
- Under Associated Servers, click Disassociate in the row of the target ECS, or select the target ECS from the list and then click Disassociate in the upper left corner of the list.
- When the target ECS is being backed up, you can still disassociate it. However, the backup job will continue and backups will be generated.
- After an ECS is disassociated from the associated backup policy, its existing backups will not be deleted. If you want to delete them, manually delete them.
- Click OK.
Parent topic: Backup Policies
