- What's New
- Getting Started
- User Guide
Best Practices
- Using a Custom Script to Implement Consistent Backup for MySQL
- Using a Custom Script to Implement Consistent Backup for SAP HANA
- Using a Custom Script to Implement Consistent Backup for Other Linux Applications
- Troubleshooting a Custom Script Error
- Verifying the Application-Consistent Backup Result (Linux)
- Verifying the Application-Consistent Backup Result (Windows)
- Protecting SQL Server in Failover Cluster Mode
- Protecting SQL Server in Always on Availability Groups Mode
- Change History
- API Reference
About Concepts
- What Is CSBS?
- What Are Full Backup and Incremental Backup?
- What Is Consistent Backup?
- What Are the Differences Between CSBS and VBS?
- What Is a Backup Policy?
- What Are the Differences Between Backup and Disaster Recovery?
- What Are the Differences Between Backup and Snapshot?
- Why Is the Disk Space Usage Displayed in the File System Different from the Backup Size?
About Pricing
- How Is CSBS Billed?
- How Do Yearly/Monthly Resource Packages Function When I Have Bought More Than One?
- Are CSBS and VBS Resource Packages Interoperable Between CSBS and VBS?
- Why Am I Charged in Pay-per-use Mode Although I Have Purchased Resource Package?
- What Exactly Are the Function Package and the Storage Package?
- Will the CSBS Backups Displayed on the VBS Page Be Charged Repeatedly?
- How Do I Query CSBS Pay-Per-Use Billing Details?
- Why Is the Fee Deducted After a Backup Is Deleted?
- How Do I Disable CSBS?
- How Do I Stop CSBS from Charging?
About Backup
- Does CSBS Support Backing Up All EVS Disks on an ECS?
- Do I Need to Stop the ECS Before Backing It Up?
- Can an ECS with Application Systems Be Backed Up?
- What Are the Minimum Backup Frequency and Maximum Number of Retained Backups Supported by CSBS?
- How Can I Distinguish Automatic Backups From Manual Backups?
- How Can I Configure a Backup Policy?
- Can I Choose to Back Up Only Some Partitions of a Disk?
- Does CSBS Support Cross-Region Backup for ECSs?
- Which Types of Databases Can Be Backed Up Using Database Server Backup?
- How Do I Select Among Database Server Backup, Cloud Server Backup, and Disk Backup?
- How Do I Migrate ECS Data Across Regions Using CSBS?
- Which Time Zone Is the Automatic Backup Time Based On?
- What Can I Do If a Backup Cannot Be Deleted?
- About Restoration
- Others
About Concepts
- Troubleshooting
- Videos
- Glossary
More Documents
User Guide (Paris and Amsterdam Regions)
- Getting Started
- Management Operations
- About Concepts
About Backup
- About Restoration
- Others
- Troubleshooting Cases
- Change History
- API Reference (Paris and Amsterdam Regions)
Show all
Using Backups to Restore ECSs
When EVS disks on an ECS are faulty or ECS data is lost due to misoperations, you can use a backup to restore the ECS.
Context
- CSBS supports backup and restoration of all EVS disks as a whole instead of part of the EVS disks on an ECS.
- Data on data disks cannot be restored to system disks.
- CSBS does not support restoration to ECSs that are in the Faulty, Resizing, or Verifying resizing state.
- EVS disks on the ECS whose data needs to be restored are running properly.
- The ECS whose data needs to be restored has at least one Available backup.
- Log in to the CSBS management console.
- Under Storage > Cloud Server Backup Service.
- Click the Backups tab. Locate the backup for the ECS. For details, see Viewing a Backup.
- In the row of the backup, click Restore. See Figure 1.
NOTICE:
The historical data at the backup point in time will overwrite the current ECS data. The restoration cannot be undone.
- Optional: Deselect Start the server immediately after restoration.
If you deselect Start the server immediately after restoration, manually start the ECS after the restoration is complete.
NOTICE:
VMs are shut down when restoring ECSs. Therefore, perform a restoration job during off-peak hours.
- In the Specified Disk drop-down list, select the target EVS disk to which the backup will be restored.
- If the ECS has only one EVS disk, the backup is restored to the only EVS disk by default.
- If the ECS has multiple EVS disks, the backup will be restored to the original EVS disk. Alternatively, you can specify another EVS disk for the restoration. The specified EVS disk must have an equal capacity to or a larger capacity than the original EVS disk.
- Click OK and confirm the restoration is successful.
In the backup list, view the restoration status. When the backup enters the Available state and no new failed restoration job exists in Task Status, the restoration is successful.
To query failed restoration jobs, see Processing Failed Jobs.
NOTICE:
If a Windows ECS is restored, data disks may fail to be displayed due to Windows limitations.
You need to manually set these data disks to be online. For details, see Data Disks Are Not Displayed After a Windows Server Is Restored.
