Updated on 2026-09-14 GMT+08:00
Example: Configuring SNAT Protection Rules
This section describes how to configure SNAT-based defense. For more parameter settings, see Configuring Protection Rules to Block or Allow NAT Gateway Border Traffic.
SNAT Protection Configuration
Assume your private IP address is 10.1.1.2 and the external domain name accessed through the NAT gateway is www.example.com. Configure NAT protection as follows and set other parameters based on your deployment:
Figure 1 Configuring a NAT protection rule
Table 1 Configuring a NAT protection rule
Example Value
Direction
SNAT
Direction of the protected traffic.
Source
IP Address/IP address group/Countries and regions
IP Address
10.1.1.2
Origin of network traffic.
Destination
IP Address/IP address group/Countries and regions/Domain name/Domain name group:
Network domain name group, www.example.com
Receiver of network traffic.
Service
Service
TCP, 1-65535, 1-65535
Protocol, source port, and destination port of network traffic.
Application
Application
HTTP, HTTPS
Protection policy for application layer protocols.
Protection Action
Allow
Action taken when traffic passes through the firewall.
Follow-up Operations
Checking protection outcomes: After your services run for a period of time, you can check the protection rule hits and adjust them in time.
References
