Disabling VPC Border Protection
If your workloads are blocked by mistake, you can temporarily disable the VPC border firewall. The firewall does not check any traffic while it is disabled.
If you no longer need VPC border traffic protection, manually restore the configuration of the enterprise router after disabling the protection. For details, see Restoring the Enterprise Router Configuration After VPC Border Protection Is Permanently Disabled.
Impacts on Services
After the firewall is disabled, traffic at the VPC border will not be protected. Exercise caution when performing this operation.
Disabling a VPC Border Firewall (New Edition)
- Log in to the CFW console.
- Click
in the upper left corner of the management console and select a region or project.
- (Optional) Switch to another firewall instance. Select a firewall from the drop-down list in the upper left corner of the page.
- In the navigation pane, choose Assets > Inter-VPC Border Firewalls.
- Click Disable Protection on the right of Firewall Status.
- Click OK.
Disabling VPC Border Firewall (Old)
- Click
- In the Operation column, click Disable Protection.
