Managing Security Reports
This section describes how to manage security reports, including enabling, disabling, modifying, and deleting security reports.
- A security report is retained for only three months. You are advised to periodically download security reports for audit.
- A custom security report cannot be modified. If you need to modify a custom security report, delete it and create a new one.
Enabling/Disabling the Security Report Function
- Log in to the CFW console.
- Click
in the upper left corner of the management console and select a region or project.
- (Optional) Switch to another firewall instance. Select a firewall from the drop-down list in the upper left corner of the page.
- In the navigation tree on the left, choose .
- Toggle on or off the switch in the upper right corner of the target report to change the status.
: enabled
: disabled
Modifying a Security Report
- Click
- Click Edit in the lower right corner of the target report to modify the report information.
Table 1 Parameters of the security report template Parameter
Report Name
Name of a security report
Report Type
- Daily
Statistical period: 00:00:00 to 24:00:00 every day
A report will be sent to the recipients the day after it is generated.
- Weekly
Statistical period: 00:00:00 on Monday to 24:00:00 on Sunday
A report will be sent to the recipients at the specified time after it is generated.
Report Schedule
When Report Type is set to Daily or Weekly, you need to set the report sending time. By default, the log report of the previous statistical period is sent.
Recipient Group
Select a topic from the drop-down list to configure the endpoints for receiving the log report.
If there are no topics, click View Topic and perform the following steps to create a topic:- Create a topic. For details, see Creating a Topic.
- Add one or more subscriptions to the topic. You will need to provide a phone number, email address, function, platform application endpoint, DMS endpoint, or HTTP/HTTPS endpoint for receiving alarm notifications. For details, see Adding a Subscription.
- Confirm the subscription. After the subscription is added, confirm the subscription.
- Daily
- Click OK. A security report is modified.
Deleting a Security Report
- Click
- Click Delete in the lower right corner of the target report to delete the report.
