Updated on 2025-09-24 GMT+08:00
Creating a VPC Border Firewall
A VPC border firewall can collect statistics on communication traffic between VPCs, helping you detect abnormal traffic. This section describes how to create a VPC border firewall.
  • You have an enterprise router.
  • To create a VPC border firewall, you need to configure an inspection VPC that consumes a VPC protection quota for traffic diversion. The current account must have a VPC that does not transmit traffic and has no subnets associated, and the VPCs under the account can create at least 2 route tables.
  1. Log in to the CFW console.
  2. Click in the upper left corner of the management console and select a region or project.
  3. (Optional) Switch to another firewall instance. Select a firewall from the drop-down list in the upper left corner of the page.
  4. In the navigation pane, choose Assets > Inter-VPC Border Firewalls.
  5. Configure the subnets associated with the enterprise router and the cloud firewall, respectively. Click Create Firewall. Configure the enterprise router and associated subnets.
    Figure 1 Creating a VPC border firewall (old version)
    Table 1 Parameters for a VPC border firewall
    Example Value
    Select an enterprise router. For details, see Viewing Enterprise Routers.
    cfw-er
    Inspection VPC
    Select a VPC. The inspection VPC cannot use the network segments already specified in other VPCs associated with the enterprise router.
    vpc-cfw-er
    IPv4 Segment
    After you select a VPC, the IPv4 address is automatically displayed.
    xx.xx.0.0/16
    AZ
    Select an AZ.
    AZ1
    Subnet
    (Subnet Associated with Enterprise Router)
    Subnet name.
    cfw-er-1
    Subnet
    (Subnet Associated to Cloud Firewall-1)
    cfw-er-2
    Subnet
    (Subnet Associated to Cloud Firewall-2)
    cfw-er-3
    IPv4 CIDR Block
    IPv4 CIDR Block
    • Ensure the value must not conflict with existing subnets.
    • Ensure the three subnet segments do not conflict with each other.
    xx.xx.1.0/24
    IPv4 CIDR Block (Subnet 1 Associated with a Cloud Firewall-1)
    xx.xx.2.0/24
    IPv4 CIDR Block
    xx.xx.3.0/24
  6. Click OK. The firewall will be created in 3 to 5 minutes.
    During the creation, you can only check the Dashboard page. The firewall status will change to Upgrading.
