Adding a Custom IPS Signature
Companies need customized intrusion detection solutions to cope with diverse complex attacks. Signature rules that are too general may cause a large number of false positives, reducing defense efficiency. CFW supports refined custom IPS signature rules for HTTP, TCP, UDP, POP3, SMTP, and FTP protocols. It can identify malicious traffic through accurate signature matching.
You can add custom IPS signatures. Be specific when configuring custom signatures. If your rules are too general, they may cause false matching and performance deterioration.
- Only the professional edition supports custom IPS signatures.
- A maximum of 500 signatures can be added.
- Custom IPS signatures are not affected by the change of the basic protection mode.
- Content can be set to URI only if Direction is set to Client to server and Protocol Type is set to HTTP.
- Log in to the CFW console.
- Click
in the upper left corner of the management console and select a region or project. - (Optional) Switch to another firewall instance. If there are multiple firewall instances, you can select a desired instance from the drop-down list in the upper left corner of the page.
- In the navigation pane, choose . In the Custom IPS Signature area, click Check Rules. Figure 1 Checking rules
- Click Add Custom IPS Signature in the upper left corner of the list and configure parameters.
Table 1 Custom IPS signature parameters Parameter
Basic Information
Name
Signature name.
It must meet the following requirements:- Only uppercase letters (A to Z), lowercase letters (a to z), numbers (0 to 9), and the following special characters are allowed: -_
- A maximum of 255 characters are allowed.
Risk Level
Risk level of the signature.
Rule Type
Rule type of the signature.
Affected Software
Affected software.
OS
OS.
Match Condition
Direction
Direction of the traffic matching the signature. Its value can be:
- Any: Any direction. Traffic in any direction that meets other specified conditions matches the current rule.
- Server to client
- Client to server
Protocol Type
Protocol type of the signature.
Source Port
Source port.
If you select Include or Exclude, you need to set the source port.- You can set one or more ports. Use commas (,) to separate multiple ports, for example, 80,100.
- You can also set a port range. Use hyphens (-) to separate ports, for example, 80-443.
Destination Port
Destination port.
If you select Include or Exclude, you need to set the destination port.- You can set one or more ports. Use commas (,) to separate multiple ports, for example, 80,100.
Action
Action taken by the firewall when it detects traffic with the signature.
- Observe: Attacks are detected and recorded in logs. For details about how to query logs, see Log Query.
- Intercept: Attacks are automatically blocked.
Before you enable the Intercept mode, you are advised to select Observe first and check whether the attack logs are correct for a period of time.
Content
Content matching the signature rule.- Content: content field that matches the signature, for example, cfw.
- Content Option: Select a rule for content matching.
- Hexadecimal: The content must be in hexadecimal format. Example: 0x1F
- Case insensitive: Match content without checking cases.
- URL: Match the fields that are consistent with the content in URLs.
- Relative Position specifies the start position in a signature matching.
- Head: The start position depends on the Offset from the head. For example, if Offset is 10, the content check starts from the eleventh bit. NOTE:
If Content Option is set to URL, the matching position of the header starts from the end of the domain name (including the port number).
For example, if the URL is www.example.com/test and the Offset is 0, the content check starts from the slash (/) following com.
If the URL is www.example.com:80/test and the Offset is 0, the content check starts from the slash (/) after 80.
- After previous content: Packet capture starts from the specified position.
Formula: Start position = Length of the previous Content field + Previous Offset + Offset + 1
For example, if the previous content is test, the previous offset is 10, and the current offset is 5, the start position is the 20th (4+10+5+1) bit.
- Offset specifies the start position of signature matching. For example, if the offset is 10, the start position is the eleventh bit.
- Depth specifies the end position of signature matching. For example, if the depth is 65,535, the end position is the 65,535th bit.
NOTE:- Depth must be greater than the length of the Content field.
- Up to four items can be added to an IPS signature.
- Click OK.
References
- Managing custom IPS signatures:
- To copy a custom IPS signature, click Copy in the Operation column, modify parameters, and click OK.
- To modify a custom IPS signature, click Edit in the Operation column. Modify parameters and click OK.
- To delete a custom IPS signature, click in the Operation column. In the dialog box that is displayed, click OK.
- To delete multiple custom IPS signatures at a time, select signatures and click Delete above the list. In the dialog box that is displayed, click OK.
- To modify the action of a custom IPS signature, choose or in the Operation column.
- To change the actions of multiple custom IPS signatures at a time, select signatures and click Observe or Intercept above the list.
- For details about attack defense, see Attack Defense Overview.
- For details about how to block network attacks, see Configuring Basic IPS Protection.
Follow-up Operations
For details about the protection overview, see Event Center. For details about logs, see Viewing Attack Event Logs.
