Configuring Logs
You can record attack event logs, access control logs, and traffic logs to Log Tank Service (LTS) and use these logs to quickly and efficiently perform real-time decision analysis, device O&M, and service trend analysis.
LTS analyzes and processes a large number of logs. It enables you to process logs in real-time, efficiently, and securely.
- On the Log Query page, you can check and export log data of the last seven days. For details, see Querying Logs.
- LTS is billed by traffic and is billed separately from CFW. For details about LTS pricing, see LTS Pricing.
Configuring Logs
- Log in to the CFW console.
- Click
in the upper left corner of the management console and select a region or project. - (Optional) Switch to another firewall instance. Select a firewall from the drop-down list in the upper left corner of the page.
- In the navigation pane on the left, choose Log Audit > Log Management. The Log Management page is displayed. Click Configure LTS Synchronization. Toggle on
to enable the cloud log interconnection service. - Create log groups and log streams. For details, see Creating Log Groups and Log Streams.
To make it easier for you to view, you are advised to:
- Add -cfw as the suffix when creating a log group.
- When creating log streams, add the suffixes -attack, -access, and -flow to attack event logs, access control logs, and traffic logs.
- Select a created log group or log stream. Select a log group, enable and select log streams, and click OK.
- The formats of attack logs, access logs, and traffic logs are different. You need to configure different log streams for them.
- Attack logs: record attack alarm information, including the attack event type, protection rule, protection action, quintuple, and attack payload.
- Access logs: record information about the traffic that matches the ACL policy, including the matching time, quintuple, response action, and the matched access control rule.
- Traffic logs: record information about all traffic passing through the CFW, including the start time, end time, quintuple, number of bytes, and number of packets.
- After the configuration is complete, if a message indicating insufficient permissions is displayed, grant the LTS FullAccess permission.
