Help Center/ Cloud Firewall/ User Guide/ Using Cloud Eye to Monitor CFW/ Configuring Alarm Monitoring Rules
Updated on 2025-12-18 GMT+08:00
You can set CFW alarm rules to customize the monitored objects and notification policies, and set parameters such as the alarm rule name, monitored object, metric, threshold, monitoring scope, and whether to send notifications. This helps you learn the CFW protection status in a timely manner.
  1. Log in to the Cloud Eye console.
  2. Click in the upper left corner of the management console and select a region or project.
  3. In the navigation pane on the left, choose Alarm Management > Alarm Rules.
  4. In the upper right corner of the page, click Create Alarm Rule.
  5. Configure parameters as prompted. Key parameters are described below. For more information, see Creating an Alarm Rule.
    • Alarm Type: Metric
    • Resource Type: Cloud Firewall
    • Dimension: Cloud Firewall Instances
  6. Click Create. In the displayed dialog box, click OK.
