Updated on 2025-12-18 GMT+08:00
CFW Monitored Metrics
This topic describes metrics reported by CFW to Cloud Eye as well as their namespaces and dimensions. You can use APIs provided by Cloud Eye to query the metrics of the monitored object and alarms generated for CFW. You can also query them on the Cloud Eye console.
Namespace
SYS.CFW
A namespace is an abstract collection of resources and objects. Multiple namespaces can be created in a single cluster with the data isolated from each other. This enables namespaces to share the same cluster services without affecting each other.
The following metrics are supported only in CN North-Ulanqab1, CN-Hong Kong, and CN East-Shanghai1:
  • internet_protection_traffic
  • vpc_protection_traffic
  • internet_protection_traffic_inbound
  • internet_protection_traffic_outbound
  • ips_allow_count
Metrics
The metrics described in Table 1 are old. You are advised to use the metric in Table 2.
Table 1 CFW metrics (not recommended)
Metric ID
Metric Name
Value Range
Unit
Number System
Dimension
Monitoring Period (Original Metric)
used_protection_bandwidth
Boundary Protection Bandwidth Usage (Mbps)
Used Internet bandwidth detected by CFW in the last 5 minutes
≥ 0
Value type: Float
KB/s
1000(SI)
fw_instance_id
5 minutes
protection_bandwidth_usage
Boundary Protection Bandwidth Usage (%)
Internet bandwidth usage rate detected by CFW within 5 minutes.
Usage rate = Used bandwidth/Bandwidth quota
≥ 0
Value type: Float
Percentage
N/A
fw_instance_id
5 minutes
Table 2 CFW metrics
Metric ID
Metric Name
Value Range
Unit
Number System
Dimension
internet_protection_bandwidth_usage
Internet Boundary Protection Bandwidth Usage (Mbps)
Bandwidth usage (Mbps) for protection at the Internet boundary.
≥ 0
Value type: Float
Bit/s
1000(SI)
fw_instance_id
Every minute
vpc_protection_bandwidth_usage
Inter-VPC Protection Bandwidth Usage (Mbps)
Bandwidth usage (Mbps) for inter-VPC protection.
≥ 0
Value type: Float
Bit/s
1000(SI)
fw_instance_id
Every minute
internet_protection_bandwidth_usage_rate
Internet Boundary Protection Bandwidth Usage (%)
Bandwidth usage (%) for protection at the Internet boundary.
≥ 0
Value type: Float
N/A
fw_instance_id
Every minute
vpc_protection_bandwidth_usage_rate
Inter-VPC Protection Bandwidth Usage (%)
Bandwidth usage (%) for inter-VPC protection.
≥ 0
Value type: Float
N/A
fw_instance_id
Every minute
internet_protection_pps
Internet Boundary Firewall PPS
PPS of protected objects at the Internet border.
≥ 0
Value type: Float
N/A
fw_instance_id
Every minute
vpc_protection_pps
Inter-VPC Firewall PPS
PPS of inter-VPC protected objects.
≥ 0
Value type: Float
N/A
fw_instance_id
Every minute
ips_hit_count
IPS Rule Hits
Number of times that traffic matches IPS rules.
≥ 0
Value type: Int
N/A
fw_instance_id
Every minute
ips_deny_count
IPS Rule Block Count
Number of times that traffic is blocked based on IPS rules.
≥ 0
Value type: Int
N/A
fw_instance_id
Every minute
acl_hit_count
ACL Rule Hits
Number of times that traffic matches ACL rules.
≥ 0
Value type: Int
N/A
fw_instance_id
Every minute
acl_deny_count
ACL Rule Block Count
Number of times that traffic is blocked based on ACL rules.
≥ 0
Value type: Int
N/A
fw_instance_id
Every minute
internet_protection_bandwidth_usage_inbound
Inbound Protection Bandwidth
Inbound Internet protection bandwidth of the firewall.
≥ 0
Value type: Float
Bit/s
1000(SI)
fw_instance_id
Every minute
internet_protection_bandwidth_usage_outbound
Outbound Protection Bandwidth
Outbound Internet protection bandwidth of the firewall.
≥ 0
Value type: Float
Bit/s
1000(SI)
fw_instance_id
Every minute
internet_protection_bandwidth_usage_rate_inbound
Inbound Protection Bandwidth Usage
This metric = Inbound Internet protection bandwidth of the firewall/Internet Border Protection Bandwidth
≥ 0
Value type: Float
N/A
fw_instance_id
Every minute
internet_protection_bandwidth_usage_rate_outbound
Outbound Protection Bandwidth Usage
Outbound Internet protection bandwidth usage (%).
≥ 0
Value type: Float
N/A
fw_instance_id
Every minute
internet_protection_pps_inbound
Inbound PPS
PPS of Internet access to firewall-protected objects.
≥ 0
Value type: Float
N/A
fw_instance_id
Every minute
internet_protection_pps_outbound
Outbound PPS
PPS of firewall-protected objects accessing the Internet.
≥ 0
Value type: Float
N/A
fw_instance_id
Every minute
Internet Protection Traffic
Traffic of the protected objects of a firewall.
≥ 0
Value type: Float
  • KB
  • MB
  • GB
  • Byte
1000(SI)
fw_instance_id
Every minute
Inter-VPC Protection Traffic
Traffic between the VPCs protected by a firewall.
≥ 0
Value type: Float
  • KB
  • MB
  • GB
  • Byte
1000(SI)
fw_instance_id
Every minute
Inbound Internet Protection Traffic
Inbound Internet protection traffic of a firewall.
≥ 0
Value type: Float
  • KB
  • MB
  • GB
  • Byte
1000(SI)
fw_instance_id
Every minute
Outbound Internet Protection Traffic
Outbound Internet protection traffic of a firewall.
≥ 0
Value type: Float
  • KB
  • MB
  • GB
  • Byte
1000(SI)
fw_instance_id
Every minute
ips_allow_count
IPS Rule Allow Count
Number of times that traffic is allowed based on IPS rules.
≥ 0
Value type: int
N/A
fw_instance_id
Every minute
Dimension
Key
Value
fw_instance_id
A firewall ID is a CFW instance ID. It is automatically generated by the system after CFW is created.
You can obtain the value of this parameter by referring to Querying the Firewall List.
  • By default, if fw_instance_Id is not specified, information about the first firewall under the account is returned. If fw_instance_Id is specified, information about the firewall with this fw_instance_Id is returned.
  • If object_Id is specified, information about the firewall with this object_Id is returned by default. If both fw_instance_Id and object_Id are specified, the specified object_Id must belong to the specified firewall.
