Help Center/
Cloud Firewall/
User Guide/
Enabling VPC Border Traffic Protection/
Enterprise Router Mode (New)/
Enabling the VPC Border Firewall and Ensuring the Traffic Passes Through CFW
A new firewall is disabled by default. Traffic passes through the enterprise router without being forwarded to the new firewall. You can enable a VPC border firewall as needed.
Enabling a VPC Border Firewall
- Click in the upper left corner of the management console and select a region or project.
- In the navigation pane on the left, click and choose . The Dashboard page will be displayed.
- (Optional) Switch firewall instance: Select a firewall from the drop-down list in the upper left corner of the page.
- In the navigation pane, choose Assets > Inter-VPC Border Firewalls.
- Click Enable Protection to the right of Firewall Status.
- Click OK.
Verifying That Traffic Passes Through CFW
- Generate traffic. For details, see Verifying Network Connectivity.
- Viewing logs. In the navigation pane, choose VPC Border Firewall.
. Click the tab and click
- If a log is generated, CFW is protecting the traffic between VPCs.
- If no logs are recorded, check the configurations of the enterprise router. For details, see Configuring the Enterprise Router to Direct Traffic to the Cloud Firewall.
Follow-up Operations
- For details about how to add a protected VPC, see Adding a Protected VPC.
- After protection is enabled, all traffic is allowed by default. CFW will block traffic based on the policies you configure.
- To implement traffic control, configure a protection policy. For details, see Adding an Internet Boundary Protection Rule or Adding Blacklist or Whitelist Items to Block or Allow Traffic.
- Allow or block traffic based on protection rules.
- Traffic allowing rule: The allowed traffic will be checked by functions such as intrusion prevention system (IPS) and antivirus.
- Traffic blocking rule: Traffic will be directly blocked.
- Allow or block traffic based on the blacklist and whitelist:
- Whitelist: Traffic will be directly allowed without being checked by other functions.
- Blacklist: Traffic will be directly blocked.
- For details about how to block network attacks, see Blocking Network Attacks.
