Updated on 2025-03-04 GMT+08:00
Adding User-defined IP Addresses and Address Groups
An IP address group contains multiple IP addresses. An IP address group frees you from repeatedly modifying access rules and allows you to manage access rules in batch.
  • A firewall instance can have up to 3800 IP address groups.
  • An IP address group can contain up to 640 IP addresses.
  • A firewall instance can contain up to 30,000 IP addresses.
Adding Custom Address Groups
  2. Click in the upper left corner of the management console and select a region or project.
  3. In the navigation pane on the left, click and choose Security & Compliance > Cloud Firewall. The Dashboard page will be displayed.
  4. (Optional) Switch to another firewall instance: Select a firewall from the drop-down list in the upper left corner of the page.
  5. In the navigation pane, choose Access Control > Object Groups.
  6. Click Add IP Address Group on the IP Address Groups tab page. In the displayed Add IP Address Group dialog box, configure parameters, as shown in Table 1.
    Table 1 IP address group parameters
    IP Address Group Name
    Name of an IP address group.
    It must meet the following requirements:
    • Only uppercase letters (A to Z), lowercase letters (a to z), numbers (0 to 9), and the following special characters are allowed: -_
    • The length cannot exceed 255 characters.
    Usage and application scenario of a rule
    • Only letters (A to Z and a to z), numbers (0 to 9), spaces, and the following characters are allowed: -_
    IP Addresses
    Enter IP addresses and click Parse to add them to the IP address list.
    The input can be:
    • A single IP address, for example, 192.168.10.5
    • Address segment, for example, 192.168.2.0/24
    • Consecutive IP addresses, for example, 192.168.0.2-192.168.0.10
    • Multiple IP addresses. Use commas (,), semicolons (;), line breaks, tab characters, or spaces to separate them. Example: 192.168.1.0,192.168.1.0/24.
  7. Confirm the information and click OK. The IP address group is added.
Adding an IP address to a user-defined address group
  6. Click the name of an IP address group on the IP Address Groups tab. The IP Address Group Details dialog box is displayed.
  7. Click Add IP Address. The Add IP Address slide-out panel is displayed.
    • To add IP addresses in batches, enter the IP addresses in the text box and click Parse.
      The input can be:
    • To add a single IP address, click Add, and enter the IP address and description.
  8. Confirm the information and click OK.
Related Operations
  • Exporting IP address groups: Click Export above the list and select a data range.
  • Batch deleting IP addresses: In the IP Address Group Details slide-out panel, select IP addresses and click Delete above the list.
Follow-up Operations
An IP address group takes effect only after it is set in a protection rule. For more information, see Adding Protection Rules to Block or Allow Traffic.
