CFW Dashboard
On the Dashboard page, you can view the basic information, overall protection capabilities, traffic topology , and statistics of firewall instances to learn about the security status and traffic of cloud assets at any time.
VPC border protection details can be viewed only after a VPC border firewall is configured.
Checking the Dashboard
- Click
in the upper left corner of the management console. Select a region.
- In the navigation pane on the left, click
and choose . The Dashboard page will be displayed.
- (Optional) Switch or view firewall instances.
- Switch to another firewall instance: Select a firewall from the drop-down list in the upper left corner of the page.
Figure 1 Switching to another firewall instance
- View firewall instance information: Click Firewall List in the upper right corner. For details, see Table 1.
Figure 2 Viewing firewall instance information
Table 1 Firewall instance information Parameter
Firewall Name/ID
Name and ID of the firewall.
Status
Firewall status.
Edition
Edition of a firewall.
Available EIP Protection Quota
Maximum number of EIPs that can be protected by the firewall.
Peak Traffic Protection
Maximum peak traffic that can be protected by the firewall.
Billing Mode
Billing mode of the current firewall.
Enterprise Project
Enterprise project that the firewall belongs to.
Operation
View details.
- On the Dashboard page, you can check the following modules:
Resource Overview
You can view the protection status of all cloud resources (EIPs and VPCs) in the current region under the current account.
Security Events
View the overall protection details of intrusion prevention to quickly locate cloud assets that need protection.
- In the upper right corner, change the query range, from 5 minutes to 7 days.
- Add a protection policy to handle the IP addresses of the abnormal external connections.
- Click the number of Abnormal External Destination IP Addresses.
- In the displayed dialog box, select an IP address.
- Generate an address group:
- Create as an address group: A new address group will be generated.
- Add to an existing address group: Add the item to an existing address group.
- Add the address group to the protection rule or blacklist/whitelist. For details, see Access Control Policy Overview.
Protection Rules
View the number of inactive policies and the total number of policies.
For details about the policies that are not matched, click the number of Policies Inactive for Over a Month to go to the Policy Assistant page and view the policies at the bottom.
Operations Dashboard
- Click the Internet Borders or Inter-VPC Borders tab to view the overall protection data of the corresponding resources.
- Peak Inbound/Outbound Traffic, Inbound/Outbound 95th Percentile Bandwidth, and Access Control:
View the traffic blocked by access control policies, the 95th percentile inbound and outbound bandwidth, and the maximum inbound and outbound traffic. For details, see Table 2.
Table 2 Peak inbound/outbound traffic, inbound/outbound 95th percentile bandwidth, and access control Time Range
Value
Last 1 hour
Maximum value within every minute
Last 24 hours
Maximum value within every 5 minutes
Last 7 days
Maximum value within every hour
Custom
- 5 minutes to 6 hours: maximum value within every minute
- 6 hours (included) to 3 days: maximum value within every 5 minutes
- 3 (included) to 7 days (included): maximum value within every 30 minutes
- Peak traffic: The system collects bandwidth in every statistical period. The maximum value within a certain period of time is regarded as the peak traffic.
For example, if the outbound peak traffic is 100 bit/s, the maximum bandwidth within a certain period of time (for example, 24 hours) is 100 bit/s.
- 95th percentile bandwidth: The system collects bandwidth in every statistical period, and sorts the bandwidth values in descending order, and removes the top 5% bandwidth values. The remaining maximum bandwidth is the 95th percentile bandwidth.
For example, if the 95th percentile bandwidth in the outbound direction is 100 bit/s, that means after the bandwidth values are sorted in descending order and the highest 5% value is removed within a certain period of time (for example, 24 hours), the remaining maximum bandwidth is 100 bit/s.
- Traffic Trend:
Inbound, outbound, and overall traffic changes. You can select Average or Maximum in the upper right corner. For details about how they are calculated, see Table 3.
Table 3 Traffic trend statistics Time Range
Average
Maximum
Last 1 hour
Average value within every minute
Last 24 hours
Average value within every 5 minutes
Last 7 days
Average value within every hour
Custom
- 5 minutes to 6 hours: average value within every minute
- 6 hours (included) to 3 days: average value within every 5 minutes
- 3 (included) to 7 days (included): average value within every 30 minutes
Note: Data is updated in real time based on traffic statistics.
- Attacks: View the accesses allowed or blocked by the intrusion prevention feature. For details about its configuration, see Configuring Intrusion Prevention.
- Access Control: View the accesses blocked or allowed by the access control policy. For details about its configuration, see Access Control.
Firewall Details
View details about the firewall instance in the Firewall Details area on the right of the page. For details about the parameters, see Table 4.
Parameter |
Description |
Related Operations |
Basic Information |
Edition |
Edition of the firewall. Options: Standard, Professional |
For details about how to upgrade the edition, see Upgrading a CFW. |
Firewall Name |
Firewall instance name. You can click |
Firewall ID |
Firewall instance ID. |
Status |
Firewall status. It takes about 5 minutes to update the firewall status after purchase or unsubscription. |
Enterprise Project |
Enterprise project that the firewall belongs to. |
Flavor |
Used/Available EIP Protection Quota |
Number of protected EIPs/Total number of EIPs under the current CFW instance. |
For details about how to purchase or unsubscribe from an expansion package, see Changing the Number of CFW Expansion Packages. |
Used/Available VPC Protection Quota |
Number of protected VPCs/Total number of VPCs under a firewall instance. |
Internet Border Protection Bandwidth |
Maximum inbound or outbound traffic of all EIPs protected by CFW. |
VPC Border Protection Bandwidth |
Peak east-west traffic that can be protected. Maximum total traffic of all VPCs protected by CFW. |
Used/Available Protection Rules |
Number of created protection rules/Total number of protection rules that can be created under a firewall instance. |
Transaction Details |
Billing Mode |
Billing mode. |
For details about the billing modes, see Billing Modes. |
Upon Expiration |
Billing policy after the firewall instance expires. |
Created |
Time at which the firewall instance is created. |
Expires |
Estimated expiration time of the firewall instance. |
Last Transaction Order |
Latest transaction order of the firewall instance. |
Tags |
Configure tags to identify firewalls so that you can classify firewall instances. For details about Tag Management Service (TMS), see Resource Tag Overview. |
