Updated on 2026-08-03 GMT+08:00
Managing Collection Tasks
You can easily and conveniently manage collection tasks in visualized form. All configurations will be retained when you upgrade the Cloud Native Cluster Monitoring add-on.
The Cloud Native Cluster Monitoring add-on 3.12.0 or later has been installed.
After you enable collection tasks that are disabled by default and add metrics except free basic metrics, you will be billed for the metrics based on AOM's standard pricing if your cluster is connected to AOM. For details, see Pricing Details.
  1. Log in to the CCE console and click the cluster name to go to the cluster console.
  2. Choose Settings from the navigation pane and click the Monitoring tab.
  3. Modify the configuration items in Collection configuration.
    For details about the configuration items, see ServiceMonitor Policies, PodMonitor Policies, and Targets.
You can create, modify, delete, start, and stop a ServiceMonitor as needed. For details about how to create a ServiceMonitor, see Method 4: Configuring ServiceMonitor.
PodMonitor Policies
You can create, modify, delete, start, and stop a PodMonitor as needed. For details about how to create a PodMonitor, see Configuring Pod Monitor.
Targets
On the Targets page, you can view the collection task status, including the collection endpoint, labels, latest collection time, latest collection duration, number of samples collected in the latest collection, and error information.
If shards are enabled for your Cloud Native Cluster Monitoring, there will be multiple collection instances. You can switch one collection instance to another in Collected Instance.
You can click the URL to view the collection result, helping you view, analyze, and manage the collection task.
