Using Dashboards
A dashboard integrates high-frequency metrics of different components from different perspectives. Different metrics are displayed on different graphs on the same screen, helping you monitor the cluster status in real time.
Dashboards display metrics in various views, such as the cluster view and pod view.
- The cluster is in the Running state.
- Monitoring Center has been enabled for the cluster.
Checking and Switching Views
- In the navigation pane, choose Monitoring Center. Then click the Dashboard tab.
The cluster view is displayed by default.
- The dashboard provides preset views. You can click the Switch View button next to the view name to select monitoring data to view.
- Configure the parameters.
- Set the time window of the view.
Select or specify the time periods in the upper right corner of the page, and click
to refresh the page.
