Updated on 2025-10-28 GMT+08:00
CCE Autopilot Cluster Patch Release History
Indexes
v1.31
Table 1 Release notes for the v1.31 patch
CCE Autopilot Cluster Patch Version
Kubernetes Version
Feature Update
Enhancement
Vulnerability Fixing
v1.31.4-r0
v1.31.4
  • Supported Kubernetes 1.31 (commercial use).
  • Supported image caches.
  • Added the CCE Secrets Manager for DEW add-on.
Fixed some security issues.
v1.31.1-r0
v1.31.1
Supported cluster v1.31. For more information, see Kubernetes 1.31 Release Notes.
v1.28
Table 2 Release notes for the v1.28 patch
Kubernetes Version
Feature Update
Enhancement
v1.28.8-r0
v1.28.15
v1.28.7-r0
v1.28.3
  • Allowed namespaces or workloads to have security groups and subnets bound.
  • Allowed creation of subdirectories for PVs that are dynamically provisioned from SFS Turbo file systems.
v1.28.6-r0
v1.28.3
  • Supported EVS volumes.
  • Supported custom disk storage capacity.
  • Enhanced cluster monitoring for better O&M.
  • Reduced pod startup time.
  • Optimized the performance of large-scale clusters.
v1.28.5-r0
v1.28.3
  • Supported APM probes during workload creation.
  • Supported access to kube-apiserver using a private IP address.
v1.28.4-r0
v1.28.3
  • Custom metrics, such as network and disk metrics, can be used to create HPA policies.
  • kube-apiserver can be accessed from a public network.
When YAML is used to create an application, the parameters that are not supported by CCE Autopilot and do not affect functionality were automatically ignored.
v1.28.3-r0
v1.28.3
  • Hosted the Everest storage add-on at the backend.
  • Supported OBS volumes.
v1.28.2-r0
v1.28.3
  • Supported CronHPA policies.
  • Supported the security context configuration for pods.
v1.28.1-r10
v1.28.3
Supported cluster v1.28. For more information, see Kubernetes 1.28 Release Notes.
v1.27
Table 3 Release notes for the v1.27 patch
Kubernetes Version
Feature Update
Enhancement
v1.27.9-r0
v1.27.4
v1.27.8-r0
v1.27.4
v1.27.7-r0
v1.27.4
v1.27.6-r0
v1.27.4
v1.27.5-r0
v1.27.4
v1.27.4-r0
v1.27.4
v1.27.3-r30
v1.27.4
Supported one-click configuration of monitoring alarms.
v1.27.3-r20
v1.27.4
  • Supported NGINX Ingress Controller.
  • Supported the Cloud Native Cluster Monitoring and Cloud Native Log Collection add-ons to monitor application metrics and collect application logs.
  • Launched the application template market.
  • Supported CustomResourceDefinitions (CRDs).
  • Interconnected with CloudShell.
Optimized the function of creating a NAT gateway by default during cluster creation so that applications can access the public network.
v1.27.3-r10
v1.27.4
Supported cluster v1.27. For more information, see Kubernetes 1.27 Release Notes.
