Creating an Nginx Ingress on the Console
- A workload is available in the cluster (because an Ingress enables network access for workloads). If no workload is available, deploy a workload by referring to Creating a Workload.
- A ClusterIP Service has been configured for the workload. For details about how to configure the Service, see ClusterIP.
- To add an Nginx Ingress, ensure that the NGINX Ingress Controller add-on has been installed in the cluster. For details, see Installing the Add-on.
- It is not recommended that you modify any configuration of a load balancer on the ELB console. If you modify the configuration on the ELB console, the Service will be abnormal. If you have modified the configuration, uninstall NGINX Ingress Controller and reinstall it.
- The URL specified in an Ingress forwarding policy must be the same as that used to access the backend Service. If the URL is not the same, 404 will be returned.
- The selected or created load balancer must be in the same VPC as the current cluster, and it must match the load balancer type (private or public network).
- The load balancer has at least two listeners, and ports 80 and 443 are not occupied by listeners.
An Nginx workload is used as an example to describe how to create an Nginx Ingress.
- In the navigation pane, choose Services & Ingresses. On the Ingresses tab, click Create Ingress in the upper right corner.
- Configure the parameters.
- Name: Enter a name for the Ingress, for example, nginx-ingress-demo.
- Namespace: Select the namespace to which the Ingress is to be added.
- nginx-ingress: This option is displayed only after the NGINX Ingress Controller add-on is installed in the cluster.
- External Protocol: The options are HTTP and HTTPS. If NGINX Ingress Controller is installed, the default port is 80 for HTTP and 443 for HTTPS. To use HTTPS, configure a server certificate.
- Certificate Source: source of a certificate for encrypting and authenticating HTTPS data transmission.
- If you select a TLS key, you must create a key certificate of the IngressTLS or kubernetes.io/tls type beforehand. For details, see Creating a Secret.
- If you select the default certificate, NGINX Ingress Controller will use its default certificate for encryption and authentication.
- SNI: an extended protocol of TLS. SNI allows multiple TLS-compliant domain names for external access using the same IP address and port, and different domain names can use different security certificates. If SNI is enabled, the client is allowed to submit the requested domain name when initiating a TLS handshake request. After receiving the TLS request, the load balancer searches for the certificate based on the domain name in the request. If the certificate corresponding to the domain name is found, the load balancer returns the certificate for authorization. Otherwise, the default certificate (server certificate) is returned for authorization.
- Forwarding Policy: When the access address of a request matches the forwarding policy (a forwarding policy consists of a domain name and URL), the request is forwarded to the corresponding target Service for processing. Click Add Forwarding Policies to add multiple forwarding policies.
- Domain Name: Enter the domain name used for access. Ensure that the entered domain name has been registered and archived. After the Ingress is created, bind the domain name to the IP address of the automatically created load balancer (IP address of the Ingress access address). If a domain name rule is configured, the domain name must always be used for access.
- Path Matching Rule
- Default: Prefix match is used by default.
- Prefix match: If the URL is set to /healthz, the URL that meets the prefix can be accessed, for example, /healthz/v1 and /healthz/v2.
- Exact match: The URL can be accessed only when it is fully matched. For example, if the URL is set to /healthz, only /healthz can be accessed.
- Path: access path, for example, /healthz.
- The access path matching rule of the Nginx Ingress is based on the path prefix separated by the slash (/) and is case-sensitive. If the subpath separated by a slash (/) matches the prefix, the access is normal. However, if the prefix is only a part of the character string in the subpath, the access is not matched. For example, if the URL is set to /healthz, /healthz/v1 is matched, but /healthzv1 is not matched.
- The access path added here must exist in the backend applications. If it does not exist, requests will fail to be forwarded.
For example, the default access URL of the Nginx application is /usr/share/nginx/html. When adding /test to the Ingress forwarding policy, ensure the access URL of your Nginx application contains /usr/share/nginx/html/test. Otherwise, 404 will be returned.
- Destination Service: Select an existing Service or create a Service. Services that do not meet search criteria are automatically filtered out.
- Destination Service Port: Select the access port of the destination Service.
- Operation: Click Delete to delete the configuration.
- Annotation: The value is in the format of key:value. You can use annotations to query the configurations supported by Nginx Ingress.
- Click OK.
After the Ingress is created, it is displayed in the Ingress list.
