- Function Overview
- Product Bulletin
- Billing
- Getting Started
User Guide
- Clusters
- Workloads
- Network
- Storage
- O&M
- Namespaces
- ConfigMaps and Secrets
- Auto Scaling
- Add-ons
- Helm Chart
- Permissions
- Settings
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
- Autopilot Cluster Management
- Add-on Management for Autopilot Clusters
Autopilot Cluster Upgrade
- Upgrading a Cluster
- Performing a Pre-upgrade Check for a Cluster
- Performing a Post-upgrade Check for a Cluster
- Backing Up a Cluster
- Obtaining Details About a Specified Cluster Upgrade Booting Task
- Quota Management for Autopilot Clusters
- Tag Management for Autopilot Clusters
Chart Management for Autopilot Clusters
- Uploading a Chart
- Obtaining a Chart List
- Obtaining a Release List
- Creating a Release
- Updating a Chart
- Deleting a Chart
- Updating a Release
- Obtaining a Chart
- Deleting a Release
- Downloading a Chart
- Obtaining Chart Values
- Kubernetes APIs
- Appendix
- Billing
- Workloads
- Network Management
- Can PVs of the EVS Type in a CCE Autopilot Cluster Be Restored After They Are Deleted or Expire?
- Can CCE Autopilot PVCs Detect Underlying Storage Faults?
- How Can I Delete the Underlying Storage If It Remains After a Dynamically Created PVC is Deleted?
- Permissions
Show all
Configuring an Image Pull Policy
When a workload is created, the container image is pulled from the image repository to the node. The image is also pulled when the workload is restarted or upgraded.
By default, imagePullPolicy is set to IfNotPresent, indicating that if the image exists on the node, the existing image is used. If the image does not exist on the node, the image is pulled from the image repository.
The image pull policy can also be set to Always, indicating that the image is pulled from the image repository and overwrites the image on the node regardless of whether the image exists on the node.
apiVersion: v1 kind: Pod metadata: name: nginx spec: containers: - image: nginx:alpine name: container-0 resources: limits: cpu: 100m memory: 200Mi requests: cpu: 100m memory: 200Mi imagePullPolicy: Always imagePullSecrets: - name: default-secret
An image pull policy can also be configured on the CCE console. When creating a workload, configure Pull Policy. If Always is selected, images are always pulled. If Always is not selected, images are pulled as needed.
Use a new tag each time you create an image. If you do not update the tag but only update the image, when Pull Policy is set to IfNotPresent, CCE considers that an image with the tag already exists on the current node and will not pull the image again.
