Help Center/ Cloud Container Engine_Autopilot/ User Guide/ Permissions/ Cluster Permissions (IAM-based Authorization)
Updated on 2025-09-23 GMT+08:00
CCE cluster-level permissions are assigned based on IAM system-defined policies and custom policies. You can use user groups to assign permissions to IAM users.
  • Cluster permissions are granted to users for operating cluster-related resources only (such as clusters and nodes). To operate Kubernetes resources like workloads and Services, you must be granted namespace permissions as well.
  • When you view a cluster on the CCE console, the information displayed depends on the namespace permissions. If you have no namespace permissions, you cannot view the resources in the cluster.
  • Before granting permissions to user groups, you need to get familiar with the system-defined policies listed in Permissions for CCE. To grant permissions on other services, you need to learn about all system-defined permissions supported by IAM.
  • A user with the Security Administrator role (for example, your account) has all IAM permissions except role switching. Only these users can view user groups and their permissions on the Permissions page on the CCE console.
Configuration Description
On the CCE console, when you choose Permissions > Cluster-Level Permissions to create a user group, you will be directed to the IAM console to complete the process. After the user group is created and its permissions are configured, you can view the information on the Cluster-Level Permissions tab. This section describes the operations in IAM.
Process Flow
Figure 1 Process of granting CCE permissions using identity policy-based authorization
  1. Create a user group and assign permissions.
    Create a user group on the IAM console, and assign CCE permissions, for example, the CCE ReadOnlyAccess policy to the group.
    CCE is deployed by region. On the IAM console, select Region-specific projects when assigning CCE permissions.
  2. Create an IAM user and add it to the user group.
    Create a user on the IAM console and add it to the user group created in 1.
    IAM users need programmatic and management console access to use CCE.
  3. Log in and verify permissions.
    In the authorized region, perform the following operations:
    • Choose Service List > Cloud Container Engine. Then click Buy Cluster on the CCE console. If a message appears indicating that you have insufficient permissions to perform the operation, the CCE ReadOnlyAccess policy is in effect.
    • Choose another service from Service List. If a message appears indicating that you have insufficient permissions to access the service, the CCE ReadOnlyAccess policy is in effect.
System-defined Roles
Roles are a type of coarse-grained authorization mechanism that defines service-level permissions based on user responsibilities. Only a limited number of service-level roles are available for authorization. However, roles are not an ideal choice for fine-grained authorization and secure access control.
The preset system role for CCE in IAM is CCE Administrator. When assigning this role to a user group, you must also select other roles and policies on which this role depends, such as Tenant Guest, Server Administrator, ELB Administrator, OBS Administrator, SFS Administrator, SWR Admin, and APM FullAccess. For more information about dependencies, see System Permissions.
System-defined Policies
The system-defined policies preset for CCE in IAM are CCE FullAccess and CCE ReadOnlyAccess.
  • CCE FullAccess: common operation permissions on CCE cluster resources, excluding the namespace-level permissions on the clusters (with Kubernetes RBAC enabled) and the privileged administrator operations, such as agency configuration and cluster certificate generation
  • CCE ReadOnlyAccess: permissions to view CCE cluster resources, excluding the namespace-level permissions of the clusters (with Kubernetes RBAC enabled)
When purchasing a CCE standard or CCE Turbo cluster or a node that is billed on a yearly/monthly basis, add custom policies and configure payment permissions such as bss:*:* for the Billing Center.
In Table 1 and Table 2, "√" indicates that the action is supported for the cluster type, and "x" indicates that the action is not supported for the cluster type.
Table 1 Permissions granted by CCE FullAccess
Action
Specific Action
CCE Standard or CCE Turbo Clusters
CCE Autopilot Clusters
cce:*:*
cce:cluster:create
Creating a cluster
cce:cluster:delete
Deleting a cluster
cce:cluster:update
Updating a cluster, for example, updating cluster node scheduling parameters and providing RBAC support to clusters
cce:cluster:upgrade
Upgrading a cluster
cce:cluster:start
Waking up a cluster
cce:cluster:stop
Hibernating a cluster
cce:cluster:list
Listing all clusters
cce:cluster:get
Obtaining cluster details
cce:node:create
Adding a node
cce:node:delete
Deleting one or more nodes
cce:node:update
Updating a node, for example, updating the node name
cce:node:get
Obtaining node details
cce:node:list
Listing all nodes
cce:nodepool:create
Creating a node pool
cce:nodepool:delete
Deleting a node pool
cce:nodepool:update
Updating a node pool
cce:nodepool:get
Obtaining a node pool
cce:nodepool:list
Listing all node pools in a cluster
cce:release:create
Creating a release
cce:release:delete
Deleting a release
cce:release:update
Updating a release
cce:job:list
Listing all cluster jobs
cce:job:delete
Deleting one or more cluster jobs
cce:job:get
Obtaining job details
cce:storage:create
Creating a storage volume
cce:storage:delete
Deleting a storage volume
cce:storage:list
Listing all storage volumes
cce:addonInstance:create
Creating an add-on instance
cce:addonInstance:delete
Deleting an add-on instance
cce:addonInstance:update
Updating an add-on instance
cce:addonInstance:get
Obtaining an add-on instance
cce:addonTemplate:get
Obtaining an add-on template
cce:addonInstance:list
Listing all add-on instances
cce:addonTemplate:list
Listing all add-on templates
cce:chart:list
Listing all charts
cce:chart:delete
Deleting a chart
cce:chart:update
Updating a chart
cce:chart:upload
Uploading a chart
cce:chart:get
Obtaining chart details
cce:release:get
Obtaining release details
cce:release:list
Listing all releases
cce:userAuthorization:get
Obtaining CCE user authorization
cce:userAuthorization:create
Creating CCE user authorization
cce:*:*
cce:imageCache:create
Creating an image cache
cce:imageCache:delete
Deleting an image cache
cce:imageCache:list
Listing all image caches
cce:imageCache:get
Viewing details about an image cache
nat:*:*
Performing all operations on NAT Gateway resources
nat:*:get
Viewing NAT Gateway resource details
nat:*:list
Listing all NAT Gateway resources
vpcep:*:*
Performing all operations on VPC Endpoint resources
ecs:*:*
Performing all operations on ECSs
evs:*:*
Performing all operations on EVS disks
EVS disks can be attached to cloud servers and expanded to a higher capacity whenever needed.
vpc:*:*
Performing all operations on a VPC, including the shared load balancers in the VPC.
A cluster must run in a VPC. When creating a namespace, you need to create or associate a VPC for the namespace so that all containers in the namespace will run in the VPC.
bms:*:get*
Viewing BMS resource details
bms:*:list*
Listing all BMS resources
ims:*:get*
Viewing IMS resource details
ims:*:list*
Listing all IMS resources
elb:*:get
Viewing ELB resource details
elb:*:list
Listing all ELB resources
sfs:*:get*
Viewing SFS resource details
sfs:shares:ShareAction
Sharing SFS resources for scaling
sfsturbo:*:get*
Viewing SFS Turbo resource details
sfsturbo:shares:ShareAction
Sharing SFS Turbo resources for scaling
tms:resourceTags:list
Listing TMS resources
kps:domainKeypairs:list
Listing DEW SSH keys
kps:domainKeypairs:get
Viewing DEW SSH keys
kms:cmk:get
Viewing DEW keys
kms:cmk:list
Listing DEW keys
aom:*:get
Viewing AOM resource details
aom:*:list
Listing AOM resources
aom:autoScalingRule:*
Performing all operations on AOM auto scaling rules
apm:icmgr:*
Performing operations on the ICAgent in APM
lts:*:*
Performing all operations on LTS
smn:*:*
Performing all operations on SMN
Table 2 Permissions granted by CCE ReadOnlyAccess
Action
Specific Action
cce:*:get
cce:cluster:get
cce:node:get
cce:job:get
cce:chart:get
cce:nodepool:get
cce:release:get
cce:imageCache:get
cce:*:list
cce:cluster:list
cce:node:list
Listing all nodes
cce:job:list
cce:chart:list
Listing all charts
cce:nodepool:list
cce:release:list
cce:storage:list
Listing all volumes
cce:*:list
cce:imageCache:list
cce:kubernetes:*
Performing operations on all Kubernetes resources. For details, see Namespace Permissions.
nat:*:get
nat:*:list
vpcep:*:get
Viewing VPC Endpoint resource details
vpcep:*:list
Listing all VPC Endpoint resources
ecs:*:get
Viewing details of all resources on an ECS
ecs:*:list
Listing all resources on an ECS
bms:*:get*
bms:*:list
ims:*:get*
ims:*:list*
evs:*:get
Viewing details about all EVS disk resources.
evs:*:list
Listing all EVS resources
evs:*:count
vpc:*:get
Viewing details about all VPC resources
vpc:*:list
Listing all VPC resources
elb:*:get
elb:*:list
sfs:*:get*
sfsturbo:*:get*
Listing all TMS resources
kms:cmk:get
Viewing DEW keys
kms:cmk:list
Listing DEW keys
aom:*:get
Viewing details about all AOM resources
aom:*:list
Listing all AOM resources
lts:*:get
Viewing details about all LTS resources
lts:*:list
Listing all LTS resources
smn:*:get
Viewing details about all SMN resources
smn:*:list
Listing SMN resources.
Custom Policies
Custom policies can be created as a supplement to the system-defined policies of CCE. For details about actions supported in custom policies, see Permissions Policies and Supported Actions.
To create a custom policy, choose either visual editor or JSON.
  • Visual editor: Select cloud services, actions, resources, and request conditions. This does not require knowledge of policy syntax.
  • JSON: Edit JSON policies from scratch or based on an existing policy.
For details, see Creating a Custom Policy. The following lists examples of common CCE custom policies.
Examples
  • Example 1: Grant permission to create a cluster named test.
        "Version": "1.1",
        "Statement": [
                "Effect": "Allow",
                "Action": [
                    "cce:cluster:create"
  • Example 2: Grant permission to deny node deletion.
    A policy with only "Deny" permissions must be used together with other policies. If the permissions granted to an IAM user contain both "Allow" and "Deny", the "Deny" permissions take precedence over the "Allow" permissions.
    Assume that you want to grant the CCEFullAccess permissions to a user but want to prevent the user from deleting nodes (cce:node:delete). You can create a custom policy for denying node deletion, and attach this policy together with the CCEFullAccess policy to the user. As an explicit "Deny" policy overrides any "Allow" policy, the user can perform all operations on nodes excepting deleting them. The following is an example of a deny policy:
        "Version": "1.1",
        "Statement": [
                "Effect": "Deny",
                "Action": [
                    "cce:node:delete"
  • Example 3: Create a custom policy containing multiple actions.
    A custom policy can contain the actions of multiple services that are of the global or project-level type. The following is an example policy containing actions of multiple services:
        "Version": "1.1",
        "Statement": [
                "Action": [
                    "ecs:cloudServers:resize",
                    "ecs:cloudServers:delete",
                    "ims:images:list",
                    "ims:serverImages:create"
                "Effect": "Allow"
CCE Cluster Permissions and Enterprise Projects
CCE supports resource management and permission allocation by cluster and enterprise project.
Note that:
  • IAM projects are based on physical isolation of resources, whereas enterprise projects provide global logical groups of resources, which better meet the actual requirements of enterprises. In addition, IAM policies can be managed based on enterprise projects. Therefore, use enterprise projects for permissions management. For details, see Creating an Enterprise Project.
  • When there are both IAM projects and enterprise projects, IAM preferentially matches the IAM project policies.
  • When creating a cluster or node using purchased cloud resources, ensure that IAM users have been granted the required permissions in the enterprise project to use these resources. Otherwise, the cluster or node may fail to be created.
  • If a resource does not support enterprise projects, the permissions granted to the resource will not take effect.
    Table 3 Enterprise project resource pool
    Support for Enterprise Projects
    Resources
    Supported
    cluster
    Clusters
    node
    Nodes
    nodepool
    Node pools
    job
    Jobs
    tag
    Cluster labels
    addonInstance
    Add-on instances
    release
    Helm releases
    storage
    Not supported
    quota
    Cluster quotas
    chart
    Charts
    addonTemplate
    Add-on templates
CCE Cluster Permissions and IAM RBAC
CCE is compatible with IAM system roles for permissions management. Use fine-grained policies provided by IAM to simplify permissions management.
CCE supports the following roles:
  • Basic IAM roles:
    • te_admin (Tenant Administrator): Users with this role can call all APIs of all services except IAM.
    • readonly (Tenant Guest): Users with this role can call APIs with the read-only permissions of all services except IAM.
  • Custom CCE administrator role: CCE Administrator
If a user has the Tenant Administrator or CCE Administrator system-defined role, the user has the cluster-admin permissions in Kubernetes RBAC and the permissions cannot be removed after the cluster is created.
If the user is the cluster creator, the cluster-admin permissions in Kubernetes RBAC are granted to the user by default. The permissions can be manually removed after the cluster is created.
  • Method 1: Choose Permissions Management > Namespace-Level Permissions > Delete in the same role as cluster-creator on the CCE console.
  • Method 2: Delete ClusterRoleBinding: cluster-creator through the API or kubectl.
When RBAC and IAM policies co-exist, the backend authentication logic for open APIs or console operations on CCE is as follows.
