Updated on 2025-08-05 GMT+08:00
Monitored Events
On Cloud Eye, you can query CBR events and alarms. You can create alarm rules to get notified when specific events happen.
Namespace
SYS.CBR
Monitored Events
Table 1 CBR events monitored by Cloud Eye
Event Name
Event ID
Severity
Solution
Impact
Backup creation failed
backupFailed
Critical
The backup creation failed.
Manually create the backup or contact technical support.
Data may be lost.
Restoration from a backup failed
restorationFailed
Critical
The resource restoration from a backup failed.
Restore the resource using another backup or contact technical support.
Data may be lost.
Backup deletion failed
backupDeleteFailed
Critical
The backup deletion failed.
Try again later or contact technical support.
Billing may be abnormal.
Vault deletion failed
vaultDeleteFailed
Critical
The vault deletion failed.
Replication failure
replicationFailed
Critical
The backup replication failed.
Data may be lost.
Backup created
backupSucceeded
Major
The backup was created.
None
None
Resource restored from a backup
restorationSucceeded
Major
The resource was succcessfully restored from a backup.
Check that data is successfully restored.
None
Backup deleted
backupDeletionSucceeded
Major
The backup was deleted successfully.
None
None
Vault deleted
vaultDeletionSucceeded
Major
The vault was deleted successfully.
None
None
Replication succeeded
replicationSucceeded
Major
The backup was replicated successfully.
None
None
Agent offline
agentOffline
Critical
The Agent is offline.
Ensure that the Agent is normal and can connect to Huawei Cloud.
Backup tasks may fail.
Agent online
agentOnline
Major
The Agent is online.
None
None
