Updated on 2026-11-26 GMT+08:00
Backup Scenario Analysis
CBR supports backup of multiple resources. You can compare the backup types to determine which one is suitable for your data.
Backup Objects and Scenarios
You can select a backup type based on the backup objects, service scenarios, and advantages described in the following table.
Table 1 Differences among the backup types
Item
Cloud Server Backup
Cloud Disk Backup
SFS Turbo Backup
Cloud Desktop Backup
What to back up
All disks (the system disk and data disks) on a server or certain disks and cloud servers running applications such as databases
One or more specific disks (the system disk or data disks)
SFS Turbo file systems
Entire Workspace desktop systems, including all disks
When to use
You want to back up entire cloud servers.
You want to back up only data disks, as the system disk contains no user data.
You want to back up only SFS Turbo file systems.
You want to back up only Workspace desktops.
Advantages
All disks on a server are backed up at the same time to ensure data consistency.
Only data of specific disks is backed up, which costs less than backing up an entire server.
File system data and their backups are stored separately, and the backups can be used to create new file systems.
Desktop data and their backups are stored separately, and the backups can be used to restore desktops.
Cloud server backup includes non-database server backup and database server backup. If you need to back up cloud servers, you can select a backup type based on the database deployment and service requirements.
Table 2 Differences between database server backup and cloud server backup
Item
Database Server Backup
Cloud Server Backup
Object
Cloud servers with MySQL or SAP HANA database deployed
Cloud servers without databases
Granularity
Cloud server
Cloud server
Vault
Server backup vault
Server backup vault
Recommended scenario
Data from cloud servers and associated databases (for example, MySQL or SAP HANA) needs to be backed up. In case of an error, all data and application configurations must be restored.
Only data of cloud servers needs to be backed up. Such data needs to be restored in case of an error.
If you use cloud server backup to back up database servers such as MySQL or SAP HANA database servers, certain database configurations may not be fully restored from the backups. This can result in startup issues when the database is restarted.
Backup Policy Settings
You are advised to configure different data backup policies based on service system levels. The following table shows the commonly used backup policies for cloud resources. You can adjust the policies based on service requirements. For details, see Creating a Backup Policy.
System Level
Backup Object
RPO
Retained
Duration
Full
Backup
Incremental
Backup
Remote
Backup
Drill
Frequency
Core system
Cloud server
4 hours
> 1 year
Weekly
6 times/day
Yes
Monthly
Cloud database
4 hours
> 1 year
Weekly
6 times/day
Yes
Monthly
4 hours
> 1 year
Weekly
6 times/day
Yes
Monthly
Important system
Cloud server
12 hours
1 year
Every two weeks
2 times/day
Yes
Quarterly
Cloud database
12 hours
1 year
Every two weeks
2 times/day
Yes
Quarterly
12 hours
1 year
Every two weeks
2 times/day
Yes
Quarterly
General system
Cloud server
24 hours
6 months
Monthly
1 time/day
No
Half a year
Cloud database
24 hours
6 months
Monthly
1 time/day
No
Half a year
24 hours
6 months
Monthly
1 time/day
No
Half a year
