Help Center/ Cloud Backup and Recovery/ User Guide/ (Optional) Resource Migration from CSBS/VBS
Updated on 2026-07-09 GMT+08:00
Context
Huawei Cloud has launched the next-generation backup service, CBR. If you have backups in CSBS or VBS but want to switch to CBR to manage these historical backups, you can migrate them to CBR in a few clicks.
If you have never used CSBS or VBS, or do not need the historical backups anymore, skip this section.
Migration Rules
During migration, CBR will automatically create vaults based on your historical resource types.
Table 1 Migration rules
Before Migration
After Migration
Servers or disks are associated with a backup policy.
If backups have been generated, CBR will create a vault with the same name (up to 64 characters) as the policy name (regardless of whether the policy is enabled) and apply the policy to the vault after the vault is created.
If no backup is generated, CBR will create a vault only when the policy is enabled. The policy applying rule and vault naming rule are the same as above.
Servers or disks are associated with a backup or replication policy.
If no backup is generated and the policy is disabled, only the policy will be migrated.
Backup or replication policies are not associated with any resource.
The policies will be migrated.
Application-consistent backup is enabled.
CBR will create a database server backup vault and name the vault with the policy name.
Backup replicas are generated.
CBR will create a replication vault named default to store generated backup replicas.
An image is created using a backup and a tag is added to the image.
The backup will fail to be migrated. Go to the IMS console, delete the tag and then migrate the backup again. After the backup is migrated, add the tag if needed.
Other backups, including manual backups, will be stored in a server backup vault named default. Different vaults will be created based on different types of resources. For example, CBR will create a disk backup vault to store the migrated disk backups.
If backups are migrated from any of the following regions, all backups in these regions will be migrated: CN East-Shanghai1, CN North-Beijing4, CN South-Guangzhou, CN-Hong Kong, AP-Singapore, and AP-Bangkok. To migrate backups in a region not listed here, switch to that region and proceed with the migration.
After the migration, backups created using CBR will also be displayed on the VBS console, but you will be billed only once.
To delete backups from the VBS console, find these backups in CBR and delete them. Then, the backups will also be deleted from the VBS console.
Based on the preceding rules, the capacity of each vault created by the system is predefined as 1.2 times the total backup size.
For example, you have a 100-GB ECS and a 50-GB ECS. The used storage capacity of the two ECSs is 20 GB and 10 GB, respectively. You have manually backed up the two ECSs using cloud server backup. During migration, the capacity of the vault automatically created will be 1.2 times the total backup size. In this example, the total backup size multiplied by 1.2 is 36 GB. So CBR will automatically create a 36-GB vault.
  • By default, a system-created vault is billed on a pay-per-use basis. If you want to switch to yearly/monthly billing, follow the instructions in Changing from Pay-per-Use to Yearly/Monthly.
  • After resources are migrated, VBS and CSBS will be unavailable. CBR uses new billing standards. For more information, see CBR Pricing Details.
  • The vaults you have purchased cannot be used for migration. Resources will be automatically migrated to system-created vaults.
  • Backup resources of one account only need to be migrated once.
  • During the migration, do not delete the CBR backup vault that is automatically created. Use it after the migration is complete.
  • After resources are migrated, disk backups and server backups will be automatically stored in CBR vaults. No further operations are required.
  1. Log in to the CBR console. Click in the upper left corner and select a region.
  2. Click Migrate to CBR in the upper right corner. Read the content in the displayed dialog box and click OK.
    Figure 1 Migrating resources to CBR
  3. The system will automatically migrate resources. After the migration, a vault named default will be created and a message will be displayed in the upper part of the page indicating that the migration is successful.
FAQ
  1. Why Are CBR Backups Displayed on the VBS Console?
    If you have migrated data from CSBS or VBS to CBR and created a backup on the CBR console, the same backup record will be generated on the VBS console. This is due to an underlying mechanism. The VBS console displays all backups generated by CBR, CSBS, and VBS. These backups will not be billed repeatedly.
  2. How Do I Delete Backups from the VBS Console?
    After you migrated data from CSBS or VBS to CBR, backups displayed in the VBS console cannot be deleted alone. Find these backups in CBR and delete them. Then, the backups will also be deleted from the VBS console.
  3. What Are the Differences Between CBR, CSBS, and VBS?
    CBR integrates CSBS and VBS. In addition, CBR supports SFS Turbo backup. The usage and billing of CBR are also different from CSBS and VBS.
  4. What Can I Do If a Resource Has Been Associated with CSBS or VBS?
    Choose Cloud Server Backup Service or Volume Backup Service from the service list. On the corresponding service console, check whether there are resources associated with policies on the Policies tab. If so, disassociate the resources from the policy and go to the CBR console to associate the resources with a vault.
