Deleting a Policy
You can delete policies if they are no longer needed.
At least one policy has been created.
If a backup or replication policy has been associated with a vault, you must disassociate the policy from the vault before deleting the policy.
- Log in to the CBR console. Click
in the upper left corner and select a region. - In the navigation pane, choose Policies.
- Click the Backup Policies tab, locate the row that contains the policy you want to delete, and click Delete.
Deleting a policy will not delete the backups generated based on the policy. You can manually delete unwanted backups.
- In the displayed dialog box, confirm the information, enter DELETE, and click OK.
After the policy is deleted, a message appears in the upper right corner. If the policy no longer exists in the policy list, it was deleted successfully.
