Help Center/ Cloud Backup and Recovery/ User Guide/ Vault Management/ Dissociating Resources from a Vault
Updated on 2026-07-09 GMT+08:00
If a resource no longer requires backup due to service changes or data migration, you can dissociate it from the vault to free up space, lower cloud storage costs, and enhance backup efficiency.
After a resource is dissociated from a vault, the vault's backup or replication policy no longer applies to the resource. In addition, all manual and automatic backups of this resource will be deleted. Deleted backups cannot be used to restore data anymore.
Dissociating a resource from a vault does not impact the performance of the services that use the resource.
  1. Log in to the CBR console. Click in the upper left corner and select a region.
  2. Locate the target vault and click its name.
  3. In this example, cloud servers will be used as an example to illustrate the process. Click the Associated Servers tab. Find the target server and click Dissociate in the Operation column. See Figure 1.
    Figure 1 Dissociating a server
  4. Confirm the information, enter DISSOCIATE, and click OK.
    After the dissociation, the result is displayed in the upper right corner. If the target server is not displayed in the Associated Servers list, the dissociation is successful.
