- Billing
- Getting Started
User Guide
- Overview
- Permissions Management
- Environment Management
- Application Management
- Component Management
- Instance Management
- Component Configurations
- Component O&M
- System Settings
- Key Operations Recorded by CTS
Best Practices
- CAE Best Practices
- Using CAE to Host Nginx Static File Servers
- Interconnecting GitLab with Jenkins for Automatic Build and Deployment on CAE
- Deploying Components Based on the Dependency Sequence Using the Jenkins Pipeline
- Deploying Spring Cloud Applications to CAE to Automatically Connect to the Nacos Engine
- Graceful Startup of a Spring Cloud Application
- Health Check
- Lifecycle Management
- Sending Event Alarms to WeCom
Connecting to the CodeArts Pipeline to Automatically Upgrade CAE Components
- Overview
- Upgrading a CAE Component After Uploading a Software Package Built Using the Pipeline to a CodeArts Release Repo
- Upgrading a CAE Component After Uploading a Software Package Built Using the Pipeline to the OBS Bucket
- Upgrading a CAE Component After Uploading an Image Built Using the Pipeline to the SWR Image Repository
- Configuring PromQL to Implement Custom Auto Scaling
- Configuring the Interconnection Between CAE and DEW to Help Applications Obtain Encrypted Secrets from DEW
- Deploying ASP.NET Core Applications to CAE
- Connecting the Network Through Enterprise Routes
- API Reference
- Component Management FAQs
Component Configuration FAQs
- Is Manual Scaling Still Effective When a Scaling Policy Is Configured?
- Can Components Be Scaled Without a Scaling Policy?
- Why Is My Instance Abnormal After Cloud Storage Is Configured?
- What Do I Do If a Component Becomes Not Ready?
- How Does CAE Support Dark Launch?
- How Do I Provide Prometheus Metrics for a Java Application?
- System Configuration FAQs
- Service Resources FAQs
Show all
CAE Operations That Can Be Recorded by CTS
With CTS, you can record operations associated with CAE for future query, audit, and backtrack operations.
After CTS is enabled, the system starts recording operations on CAE resources. You can view the operation records of the last seven days on the CTS console.
Operation |
Resource Type |
Event Name |
Creating a component |
component |
createComponent |
Deleting a component |
component |
deleteComponent |
Upgrading a component |
component |
upgradeComponent |
Starting a component |
component |
startComponent |
Stopping a component |
component |
stopComponent |
Restarting a component |
component |
restartComponent |
Scaling a component |
component |
scaleComponent |
Rolling back a component |
component |
rollbackComponent |
Deploying a component |
component |
deployComponent |
Configuring a component |
component |
configureComponent |
Creating an application |
application |
createApplication |
Deleting an application |
application |
deleteApplication |
Creating an environment |
environment |
createEnvironment |
Deleting an environment |
environment |
deleteEnvironment |
Binding cloud storage |
cloudStorage |
bindCloudStorage |
Unbinding cloud storage |
cloudStorage |
unbindCloudStorage |
Creating a certificate |
Certificate |
createCertificate |
Updating a certificate |
Certificate |
updateCertificate |
Deleting a certificate |
Certificate |
deleteCertificate |
Creating a domain name |
Domain |
createDomain |
Deleting a domain name |
Domain |
deleteDomain |
Creating a scheduled start/stop policy |
TimerRules |
createTimerRules |
Updating a scheduled start/stop policy |
TimerRules |
updateTimerRules |
Deleting a scheduled start/stop policy |
TimerRules |
deleteTimerRules |
